Author Topic: looking for these?  (Read 3382 times)
skyblast
  • Last login:June 14, 2020, 10:11:01 am
looking for these?
« on: September 23, 2008, 08:01:24 pm »
I'm trying to install mala but can't seem to find these files??
a) copy “catver.ini” into the "C:\Emulators\Programs\mame\” directory
b) copy "controls.ini" into the "C:\Emulators\Programs\mame\” directory
c) copy “history.dat” into the "C:\Emulators\Programs\mame\” directory
Where are these found?  I thought I followed the steps perfectly?  "I've searched in every folder for them?
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
Re: looking for these?
« Reply #1 on: September 23, 2008, 08:12:05 pm »
you need to download them, search google for them.
SGT
  • Last login:May 31, 2025, 10:10:32 pm
« Reply #2 on: September 23, 2008, 08:13:51 pm »
skyblast
« Reply #3 on: September 23, 2008, 08:25:07 pm »
Thanks guys!!  I hope this works.  Lastly I don't understand the the part where you are asked to do this
4) Execute the following command to go into the mame install directory:
   cd C:\Emulators\Programs\mame
When the window opens
I get C:\Documents and Setings\Tim.Home-PYXHOAUFBO>
What do I put in?
SGT
« Reply #4 on: September 23, 2008, 08:31:54 pm »
Type:
Code: [Select]
at the end of:
Code: [Select]
and then press <ENTER>
skyblast
« Reply #5 on: September 23, 2008, 09:55:48 pm »
Type:
Code: [Select]
at the end of:
Code: [Select]
SGT...I feel that you are in my corner!!  Thanks!
Ok, I did accomplish that but then I got another c prompt...was something supposed to happen?
Then I get confused again by the next step???  Just type in     mame -cc     ?
5) Execute the following command to produce a “mame.ini” file:
   mame -cc
SGT
« Reply #6 on: September 23, 2008, 10:30:55 pm »
Yes, just type it in and press <ENTER>
loadman
  • Moderator
    • MaLa
« Reply #7 on: September 23, 2008, 10:54:12 pm »
SGT  :notworthy:
