Author Topic: Trackball Question  (Read 1331 times)
rayzor45
  • Last login:October 03, 2008, 12:49:50 pm
Trackball Question
« on: September 23, 2008, 01:05:20 pm »
Hello All,
I’m new to the site and currently building a cabinet. I’m at the stage now where I have to wire everything.  My question is, how do you light a trackball using the power from the PC?  I have read that you use one of the extra 4 prong cables that are hanging off the power supply, but how do I connect it to the trackball light?  Do I cut the connector off and use one of the wires (red,black,yellow)?  Any help or pictures on this would be great. Thanks in advance for your help!
Rayzor45
Allan Bernard
  • Last login:December 06, 2008, 02:17:34 am
Re: Trackball Question
« Reply #1 on: October 29, 2008, 06:41:39 am »
I know this topic is a month old, but since there was no answer...
...here ya go:
http://nerdreviews.net/howtos/connecting-leds.shtml
You can use the power from the molex connector (the "extra 4 prong cable") _IF_ you use a correct resistor for your LED. The voltages of the molex are as follows:
red +5V
black GND
yellow +12V
Allan Bernard
GSM: (+372) 55 632 698
Tallinn, Estonia, Europe
paulscade
  • Last login:December 26, 2022, 09:40:35 pm
    • My Arcade Project - Blastoff!
« Reply #2 on: October 29, 2008, 09:04:54 am »
Does your trackball already have lighting installed (i.e. like the Electric Ice from GGG) and you're just wondering how to connect it to the PC? (Not all trackballs have preinstalled lighting).
I assume that this is the case from your statement:
"....but how do I connect it to the trackball light?"
If that's the case, 5v from the USB connection will do it.
Here's what I did using the Electric Ice trackball:
http://forum.arcadecontrols.com/index.php?topic=82241.msg897333#msg897333
... Why is it that you always find it in the last place that you look? ...
