Author Topic: Paint then drill, or drill then paint?  (Read 4033 times)
blind_dado
  • Last login:March 17, 2019, 07:34:32 pm
    • Arcade Odyssey
« on: September 18, 2008, 10:41:22 am »
When building a control panel, is it better to drill the button holes first and then paint, or the other way around?
Re: Paint then drill, or drill then paint?
« Reply #1 on: September 18, 2008, 10:47:59 am »
Most people don't use paint.  They use laminate or a printed adhesive overlay.  I imagine with paint it all comes down to how much confidence you have in making a clean hole.
blind_dado
    • Arcade Odyssey
« Reply #2 on: September 18, 2008, 10:50:54 am »
But I thought that you needed to paint before you put down your CPO so that it bonded well and the MDF was "sealed" properly.
« Reply #3 on: September 18, 2008, 11:21:22 am »
Primer.  And you don't have to care about how good the primer looks.
blind_dado
    • Arcade Odyssey
« Reply #4 on: September 18, 2008, 11:25:28 am »
I guess I'll prime then drill and skip the paint for the CPO top (and bottom).  Thanks!
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #5 on: September 18, 2008, 10:59:43 pm »
I drilled then primed due to the unprotected areas that would result from drilling out the holes.
BobtheAddict
  • Last login:October 29, 2010, 12:00:22 am
  • Icy Cold Beverages
« Reply #6 on: September 19, 2008, 09:45:38 pm »
I would suggest to drill and then spay on your primer. Although you will not see the top, it is good practice to do all your woodworking first then sand and paint.
Just my 2 nickles!
BobTheAddict
ghettodish
  • Last login:October 21, 2017, 03:41:58 pm
« Reply #7 on: December 11, 2008, 03:22:42 pm »
I drilled, oil-primed with rattle can of Cover Stain primer (Zinsser, sold at Home Depot), then sanded smooth.
