Author Topic: LF: Custom Cabinet Plans for 32inch TV ARCADE  (Read 2542 times)
heebeegb
  • Last login:June 01, 2009, 09:56:57 pm
    • HeeBeeGB
« on: September 17, 2008, 04:26:37 pm »
Lots of cabinet plans for 27inch TV arcade cabinets out there.
I have a 32inch TV that I have to accomodate for the cabinet.
I can't find any designs for this size.
It's proving very difficult to design one from scratch for this heavy TV.
clickhea
  • Last login:August 09, 2019, 07:33:40 am
Re: LF: Custom Cabinet Plans for 32inch TV ARCADE
« Reply #1 on: September 17, 2008, 04:29:40 pm »
all you need to do is make your base a bit wider
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: September 17, 2008, 04:31:34 pm »
How about a 34" Dynamo showcase?
http://www.jakobud.com/cabinetPlans.php
TAG
  • Last login:May 23, 2014, 05:52:05 pm
« Reply #3 on: September 17, 2008, 04:34:14 pm »
I would think you could simply adjust the measurements of those other plans to accomodate the dimensions of the larger TV, and then make sure that you have enough monitor shelf support for the additional weight.  My first concern, though, would be that the cabinet might be so wide that it wouldn't fit through a typical doorway!
I may not have gone where I intended to go, but I think I have ended up where I needed to be.
-- Dirk Gently
