Author Topic: Missing scrolling sound, MaLa 1.05  (Read 2666 times)
system01
  • Last login:March 04, 2023, 08:06:55 pm
  • System Idle Processes are the Devil's Playthings
« on: September 16, 2008, 09:17:56 pm »
So I just put the new MaLa (1.0.5.8) on last night and now I dont have the sound that occurs when scrolling through the list.  The sound plays at the sample button in the Sounds tab, and every other sound plays (exit, start, list change, etc) normally.  I even used a working sound as the scroll sound and still nothing.  Its also the same one I was using in 1.0.4.
Anyone else experience this with the new version?
Thx.
loadman
  • Moderator
    • MaLa
Re: Missing scrolling sound, MaLa 1.05
« Reply #1 on: September 16, 2008, 09:37:47 pm »
It works for me  ; ;D
Are you using the same mala.ini config file for 1.04 and 1.05?
The reason I ask is there is an option in options-GUI-options-display delay 'Gui Sounds'. What do you have that set to in 1.05?
I normally don't have that checked as it slows down scrolling a bit to play a wav  ;)
system01
« Reply #2 on: September 16, 2008, 10:03:46 pm »
That did it!
Funny thing is, I had the entire delay tab turned off, but some settings below were checked and grayed out.  So I checked the delay box, unchecked all of the things below, then turned delay back off.  Maybe something to look at, unless its just me. :dunno
Thanks again!
loadman
  • Moderator
    • MaLa
« Reply #3 on: September 16, 2008, 11:44:14 pm »
That did it!
Thanks again!
Not just you.
I guess that section could be labled better.
It means exceptions to scrolling at optimum speed (not including joystick or mouse settings)
So really the sound section should not be enabled or made more clear that it won't play unless that scroll delay allows it to play I guess
