Author Topic: Sound options  (Read 2959 times)
beercade
  • Last login:November 24, 2009, 09:01:51 pm
Sound options
« on: September 14, 2008, 09:36:19 am »
So Ive been using MALA for awhile and love it.  Im having sound issues thought, mainly on levels.  So my video previews have one sound level or volume which is kinda low, and my mala sound theme has a volume that is quite a bit louder which is about the same volume as the speech plugin.  Then mame is quite a bit louder.  I was able to lower the mame volume by editing the mame.ini (setting it to -6 seemed to work well) but is there a way to individualy adjust the other sounds in MALA? The vol adjust in mala seems to be a "master" which adjusts all levels.  Any ideas?
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: Sound options
« Reply #1 on: September 14, 2008, 11:47:09 am »
Is this the vol adjust that "seems to be a master"?
« Last Edit: September 14, 2008, 11:48:43 am by SGT »
beercade
Re: Sound options
« Reply #2 on: September 14, 2008, 01:11:10 pm »
No im talking about the volume that can be setup for diffrent buttons under the controler tab.  I dont use back ground music.
loadman
  • Moderator
    • MaLa
Re: Sound options
« Reply #3 on: September 14, 2008, 07:10:08 pm »
Hmm
I would resample/edit the wav's you are using to a suitable level
