Author Topic: Scott's Arcade aka NeoMAME  (Read 11478 times)
« on: September 11, 2008, 06:04:46 pm »
ahhh the trusty 2 slot cab nobody wanted:
then I got the idea to just restore it:
then I saw the South American NeoGeo cabs:
then painted it Blue:
re-added the neo geo control panel and marked it for drilling:
Everyone else has a picture of their dad doing something, so here is my dad drilling the pilot holes for the metal punch:
Heres the cab as it looks today:
Its got the arcade monitor running in it using Soft15, same computer from my Mortal Kabinet (for now this cab is already pre-sold and the lady is supplying her own PC)
All that is left to do is order the art for it in whatever theme she wants and making a door to cover the keyboard/mouse, and latch access.
For all the die-hards out there, this is FULLY REVERSIBLE, just plug the holes in the CP or just put a new overlay on it and cover it with new plexiglass. And yes, thats new T-Molding
EDIT: "named" now; no Im not Scott, and thats NOT me in the picture
« Last Edit: October 31, 2008, 12:21:49 pm by Malenko »
cmoses
Re: the unnamed NEO*GEO Mame-ing.
« Reply #1 on: September 11, 2008, 10:18:16 pm »
Can you give some more information about what you did to the metal control panel?  I have one on a cab that I am MAMEing and would consider altering the current one if I knew more about the process.  Otherwise I may have one fabricated.
It looks as though you added a few holes as well as filled some in?  I have never used a metal punch, how is that?  How big of a hole can you make with one?  I am hoping to add a trackball to mine.
Oni2382
  • Last login:December 07, 2015, 11:00:36 pm
« Reply #2 on: September 11, 2008, 10:22:23 pm »
looks good.... :cheers:   Is that oil based paint or is this a latex paint?
XBL:Mykungfooizgood
PSN: Mykungfooizgud
« Reply #3 on: September 12, 2008, 07:44:15 am »
I double punched the hole. I drilled a 1/8" hole then ran a 5/8" punch through it. then I ran a 1" punch through the 5/8" hole. The metal punch I used is for conduit and therefor the holes come out a little bigger then the hole punch size. The 1 inch punch makes a hole about 1 and 1/16th which is just about perfect for a button. The biggest punch I own does a 2" hole but I think they make a 2 1/2" or 3" one. I didnt fill in the extra hole because I dont know if the lady wants a 6 or 7 button set up so its just covered with vinyl for now, and plexiglass later. I will say this, Samurai Shodown is weird to play on a SF layout.
If you have the option of fabricating one then I'd go that route then if you ever decide to revert it back, its easier.
Enamel  paint (oil based) sprayed with a nozzle hooked to an air compressor. The paint is a 3:2 mix of paint to thinner and the color is AMAZING in person. Im going to work on dremeling out the plexiglass holes
« Reply #4 on: September 24, 2008, 10:48:17 pm »
redid the control panel. buttons weren't "square". Cut the plexi out, drilled the holes, printed some artwork up, cut the holes out of it, reinstalled the buttons, put the washers on top of the plexi, and rewired the IPAC2
relaid down the base "leature texture" vinyl
3 Angles of the completed CP
« Reply #5 on: October 31, 2008, 11:40:41 am »
here's the machine at its new home with new owner:
marquee and side art by MAMEMarquees, took about a week. Control Panel by Udon for the SF anniversary thing thing and printed out at work.
Games001
  • Last login:January 13, 2024, 12:44:04 am
Re: Scott's Arcade aka NeoMAME
« Reply #6 on: October 31, 2008, 02:23:36 pm »
Looks very nice.  I picked a blue almost exactly like yours on my very first MAMEing.. called Phantom Blue at Home Depot (if I recall correctly).
Just curious, does that marquee blind you while playing or is it just the camera flash/pickup that makes it so bright?  8)
« Reply #7 on: October 31, 2008, 02:45:34 pm »
Thats not from the home depot, lol. The pictures up top are better at showing the real shade of blue then the latest pictures. Its actually a custom shade of blue for cars (and is an enamel paint). The marquee is pretty evenly lit, so I blame the IPhone's ---smurfy--- built in camera for the way it looks.  I asked the owner for some more, better, pictures.
Games001
« Reply #8 on: October 31, 2008, 09:09:54 pm »
Any pic is a good pic.. and the blue is great nonetheless.  :applaud:
« Reply #9 on: November 03, 2008, 12:15:47 pm »
more pix, and the last of the pix, I told her I wouldnt bug her for any more.
« Reply #10 on: January 21, 2009, 05:49:24 pm »
forgot to mention this, but my GF bonnie printed out that control panel art at her job, and they have a GREAT printer. if I wasnt going to use plexiglass, I would have had mamemarquees print that out too.
She also helped me strip the sides and even primed some, oh and I took the pix with her camera :p
« Last Edit: January 21, 2009, 07:30:49 pm by Malenko »
