Author Topic: Anyone running PSXemulator?  (Read 1776 times)
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« on: September 10, 2008, 09:50:05 pm »
I've recently started using PSXemulator and can't get the music working in either Ridge Racer/ RR Revolution. I originally had rips where all the music was removed but I've managed to find ones with the complete music set. However, no matter how I try to compile them I still cannot get the music working. The files are .bin with the .cue sheets and all mp3's present but no matter what I do I only get sound effects; no music.
Any ideas?
Re: Anyone running PSXemulator?
« Reply #1 on: September 11, 2008, 09:20:54 am »
bin and cue with MP3s?   burn the first one as a data layer, then add the rest as normal CD audio tracks
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: September 11, 2008, 09:36:34 am »
The MP3s typically burn as standard CD audio.
« Reply #3 on: September 11, 2008, 09:56:17 am »
i dont think he's burning it, I think hes mounting it and its not converting the MP3 to red book audio. the music in that game sucked anyway :-)
waveryder
  • Last login:July 14, 2011, 04:26:17 am
  • I Troop, therefore I am
    • BubbleGum Custom Art
« Reply #4 on: September 11, 2008, 10:29:44 am »
That's the way to do it. If your after an image just burn it as a virtual disc. Nero, Alchol etc will do this. Better of just DL'in on of the "official US/PAL Dump sets" they are all 1:1's of psx disc's. Rotterdam Nation sounds just poo after being mp3'd to 128kbs!
When pixelated clipart just wont do, just call for Betty
jharris
« Reply #5 on: September 11, 2008, 12:04:51 pm »
I think I had the same problem you are describing. Turns out pSX (great emu but what a bad name!) is hardcoded to look for audio in the first available CD drive. I was able to fix it by changing my virtual cd settings so that the drive letter came first over the physical DVD drive. For example: if D: and E: are for your DVD burner and virtual cd drive respectively, then change your letter assignments so that D: is your virtual drive.
From there on I was able to mount cd images with cd audio tracks and pSX would play them just fine.
