Author Topic: Mala 1.04 File Tagged Malware  (Read 3171 times)
FrizzleFried
    • Idaho Garagecade
« on: September 10, 2008, 05:36:03 pm »
I am guessing the fact that Avast is reporting that the MaLaKeyHook.dll is malware is a false positive?  I just downloaded the file from the Mala site and when I attempted to extract the files I got the hit.  The problem is that I see no way to bypass the hit.  I have no option to mark it safe... any suggestions?
It identifies: Win32:Hooker-D [Tool] as the specific malware associated with this file?!
« Last Edit: September 10, 2008, 05:38:01 pm by FrizzleFried »
TheShanMan
    • My Arcade (updated 1/30/13)
Re: Mala 1.04 File Tagged Malware
« Reply #1 on: September 10, 2008, 06:47:42 pm »
I think this has come up before. You most likely don't need the dll - it is only used in win 98 IIRC, in which case deleting the file is fine. I think you can find more detailed (and possibly accurate) info on the subject if you search this forum on the dll name.
SGT
  • Last login:May 31, 2025, 10:10:32 pm
« Reply #2 on: September 10, 2008, 08:18:07 pm »
Additionally,  AVAST does allow you to add folders and files to be excluded.  I excluded MalaKeyHook.dll a long time ago.  There two types of exclusions.  One is for the scheduled scans and the other is for the "on-access" scan.  Below is the screenshot for the on-access scan exclusions which is harder to find.  The exclusion needed is:
Code: [Select]
*\malakeyhook.dll
« Last Edit: September 10, 2008, 08:33:46 pm by SGT »
