Author Topic: williams cyclone - fix  (Read 3368 times)
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« on: September 08, 2008, 11:51:38 pm »
my arcade customer had me take a look at one of his pinball units today .
strange symptom as it seldom did the same thing twice upon pwr up..... ?
decided it must be a syscon issue . suspected a reset problem as it had some other random problems as well.
C30  ( 22uF @25v) is the C part of the RC time constant for the reset generator.
wasn't too surprised when it measured out at 15 uF  and an esr reading of 350 ohms .
replacing the cap eliminated the start up symptoms.
next issue was the knocker and ball launcher would alternately kick , then also noticed the "ferris wheel" wasn't rotating .
fault was traced to a missing 25v source . the ground sides of rect bridge br1 were open.
replacing the diode restored normal ops    :)
sure glad he had a schematic !!
qrz
« Last Edit: September 09, 2008, 10:16:51 pm by qrz »
