Author Topic: MAMEWAH v0.951b Released!  (Read 4213 times)
« on: June 11, 2003, 07:19:59 pm »
This one is mainly a bug-fix, with a few improvements.  In particular, merged romsets now work (to an extent) and the (M.A.M.E.) games list can be generated without a DAT file.  Please see the attached whatsnew's for more details.
This should please 50% of you...sorry Win98 users, I haven't been able to address those problem issues yet.
Everyone who is using v0.95b should grab this tho, get it here: http://mamewah.mameworld.net :)
Re:MAMEWAH v0.951b Released!
« Reply #1 on: June 11, 2003, 07:21:11 pm »
Here's whatsnew for the Layout Designer...
colonelsnow
  • Last login:July 13, 2022, 07:56:26 am
« Reply #2 on: June 11, 2003, 09:56:54 pm »
Have you heard from anyone using Windows Me to see if they are having the same problems as Windows 98?
« Reply #3 on: June 12, 2003, 04:27:45 am »
No, not specifically.  I suspect ME would suffer similar probs...
Have you tried this version yet colonelsnow?  I just had an email from another user - this version has fixed his slow-changing-lists/emu's problem.  What's it like on yours?
BuZz880
  • Last login:November 16, 2023, 02:16:43 pm
« Reply #4 on: June 12, 2003, 09:44:49 am »
I asked MINWAH this by e-mail but he doesn't have a WIN98SE machine and since I recently figured out you were all posting here I thought I would ask here as well.
I cannot exit MAMEWAH through the menu.  Is this just me?  I have to exit via task manager which is a pain.
What happens is I hear my exit WAV and then nothing happens, this regardless of whether windows task switching is on or off or whether or not I have an exit sound on or off.
I didn't have this problem at first with MAMEWAH 95 but thjen one day it started, this new version 95b1 has not made a difference.
Obviously I have done something here - does anyone else have this problem?  If so how did you fix it?
Win98SE
ArcadeVGA
MAMEWAH95b1 (same issue on 95B and I may have had it awhile on 90 but it sort of fixed itself).
GoldenBear
  • Last login:March 27, 2004, 07:27:48 pm
  • El Oso de Oro
    • Bearz Inn
« Reply #5 on: June 12, 2003, 01:50:23 pm »
colonelsnow
What is this problem you speak of?  I am running Mamewah on WindowsME and might have it?
DLing the new version now and will reply with any problems....besides my lack of joystick control problem  ;D
GoldenBear
anthony691
  • Last login:January 29, 2016, 03:10:23 pm
    • Lightgun.tk
« Reply #6 on: June 12, 2003, 04:32:20 pm »
oh, about those "problems"... I don't have them.
I overinstalled over the last version of MAMEwha... I am running Win 98 with no probs... MAMEWAH is already a part of my cab...
Visit my MAME lightgun site:
http://www.lightgun.tk
GoldenBear
  • El Oso de Oro
    • Bearz Inn
« Reply #7 on: June 12, 2003, 05:42:07 pm »
Well, after installing the new version, I've haven't found any dramatic bugs yet.
On another high note, I downloaded a new version of my gamepad drivers and now my keymapping works properly. :D
I still think you should keep direct gamepad/joystick control as an idea for a future version though Minwah.  But now that I have my gamepad working, no rush  ;D
GoldenBear
colonelsnow
« Reply #8 on: June 12, 2003, 08:54:55 pm »
I tried the new version. My speed problems are gone!!. Thank you.
« Reply #9 on: June 12, 2003, 09:03:44 pm »
I am particularly glad  ;D
How quick does it change lists now?  I did change a very small piece of related code, but I thought it would have zero or less impact.
It's made my day if that worked  ;D :D :)
dknight
  • Last login:June 13, 2003, 09:51:52 am
« Reply #10 on: June 12, 2003, 11:07:50 pm »
I just tried out 0.951b on Win98SE and it does take less time to switch game lists from large lists.  Switching from the full list (almost 4000 games) takes about 3 seconds now.  Still noticeable, but much better than before.
Didn't try anything else yet, but just wanted to let you know.
Thanks, Minwah!
-Dave
Bill_S
  • Last login:June 22, 2018, 08:23:57 am
  • aka buzzdalf
« Reply #11 on: June 13, 2003, 09:05:45 am »
OK, I decided it was time for me to come out of the dark ages and upgrade from version 895.  So I installed versions 95 & 951 last night in a new directory to get a full install.
It looks like most of the issues that kept version 90 from running on my CAB are fixed.  I do still have one problem though.  It won't let me exit to windows after playing a game.  When I select to exit it plays the sound bite but doesn't actually do anything?!?
It's a Win98SE install.
Does anyone else have this issue?  Is there a fix for it?
This front end has come a long way from the version I'm currently running, and I'd like to get caught up :)
« Reply #12 on: June 13, 2003, 11:06:39 am »
One other user does have this problem Bill...does it do the same if you do not use an exit sound clip?  Also, are you using MP3's?
I think this is another Win'98 only bug, I'm gonna setup an old '98 PC soon, so I will investigate this while I'm at it.
Glad the game list switching is quicker for you too dknight...I'll see if there's anything else I can do to improve it further  :)
grounded
  • Last login:November 06, 2003, 11:54:25 am
  • I built my own arcade controls!
Re:MAMEWAH v0.951b Releaseed!
« Reply #13 on: June 13, 2003, 11:19:57 am »
One bug to report:
Using 951B and WinXP. When I try to type c:\nes\snap\?_02.png into the "'Artwork #1 Filename to Replace with Romname" and press enter, the ? disappears from the path.... I found a work-around by opening the config file and entering the correct path, and saving. From there on everything worked great.
« Reply #14 on: June 13, 2003, 02:21:04 pm »
One bug to report:
Well spotted...I added a routine to remove non-allowed characters from filenames / paths.  Of course I forgot about this eventuality...I'll fix it for next time :)
Tarkade
  • Last login:June 23, 2006, 03:38:04 pm
  • Newbie...
« Reply #15 on: June 13, 2003, 04:06:29 pm »
I don't know if others have reported this.  I have seen this issue with both versions of v.095.  While attempting to generate a custom list based on filters, I immediately receive a Error # '9' - Subscript out of range error.
I suspect it may have to do with my catver.ini file.  I have tried most everything I can think of.
Any suggestions?
anthony691
    • Lightgun.tk
« Reply #16 on: June 13, 2003, 05:05:22 pm »
Any suggestions?
I have the same error; it is the only bug I get. When you re-enter MAMEwah is the list generated? Mine is.
Tarkade
  • Newbie...
« Reply #17 on: June 13, 2003, 05:16:07 pm »
No - my custom list remains blank.  This is the only bug I have as well.  I am using Windows 2000 Pro if that makes a difference to anyone.
« Reply #18 on: June 13, 2003, 08:40:05 pm »
A few people are having this bug, I thought it was just in Win98, but 2000 as well it seems.  It all works fine on XP.  I'll be looking into fixing it soon :)
colonelsnow
« Reply #19 on: June 13, 2003, 09:00:20 pm »
As amazing as it is if anything now it moves too fast!. One button press at times advances two emulators.
Bill_S
  • aka buzzdalf
« Reply #20 on: June 13, 2003, 11:31:20 pm »
I was just troubleshooting a little more.  I still have the problem if I do not use an exit sound clip.  Everything works fine if I don't use any sound clips though.  I can come and go from MAMEWah as many times as I want without sound.  Also, the menu navigation is a lot slower when I use sound.  I don't know if that helps, but I have to move the joysttick and wait a second each time when  I use the sound.  When I use no sound the joystick keeps up pretty well.
One more, no - I'm not using MP3's.
Now that I got through that exiting issue I am booting into the latest MAMEWAH.  Thanks for the layout designer, that makes customizing the appearance real nice!
« Reply #21 on: June 14, 2003, 09:21:10 am »
Thanks for the info Bill, I'll keep it in mind when I get to try and fix it :)
jdjuggler
  • Last login:May 08, 2022, 10:54:37 pm
  • Hurray! I don't have pockets for quarters anyway!
« Reply #22 on: June 15, 2003, 10:05:06 pm »
I can't figure out how to use the P1 buttons 1 & 2 (ctrl&alt) to add a game to the favorites list...  I press these buttons when a game is highlighted in the Main list and nothing happens... Any ideas?
Thanks,
JD
« Reply #23 on: June 16, 2003, 04:39:11 am »
This shortcut is no longer...the 'Favorites' list has also gone, in favour of 'Custom Lists'.  If you go into 'Games List Options' you can 'Add Game to Custom List' - rename the list to 'Favorites' and you can achieve the same thing (as the old system).
I hope to add some sort of shortcut key back at some point.
Cave
  • Last login:June 07, 2009, 10:27:58 am
« Reply #24 on: June 16, 2003, 03:42:16 pm »
I'm using mamewah 951B and WinXP and I also get the # '9' - Subscript out of range error, this only happens when using  anything but romfolder to generate a games list, I also got this error when filtering clones from a full custom list , It generated about 20 games then fell over. This could be a bug on all windows versions.
« Reply #25 on: June 16, 2003, 04:57:54 pm »
Thanks Cave, I think your right...I had another report of the issue on XP a day or 2 ago.  I wonder why I haven't had it happen yet!??
colonelsnow
« Reply #26 on: June 16, 2003, 05:49:26 pm »
I am curiuos how you are "booting into mamewah"? Do you have it in your start folder or autoexec or what?
anthony691
    • Lightgun.tk
« Reply #27 on: June 16, 2003, 08:10:28 pm »
Startup folder for me :)
« Reply #28 on: June 17, 2003, 05:20:36 am »
anthony691, do you use an ArcadeVGA?  If so do you have any probs with MAMEWAH in startup, config-ed to 640x288?
Bill_S
  • aka buzzdalf
« Reply #29 on: June 17, 2003, 06:57:43 am »
Startup folder.
« Reply #30 on: June 17, 2003, 09:28:00 am »
Startup folder.
Same Q as above to you please Bill: Do you use an ArcadeVGA?  If so do you have any probs with MAMEWAH in startup, config-ed to 640x288?
I am trying to find more about a bug in XP, but may happen in others also.  Thanks
Bill_S
  • aka buzzdalf
« Reply #31 on: June 17, 2003, 12:33:53 pm »
Startup folder.
Matrox G400 on Win 98SE, sorry.  I run at 640x480 btw.
BuZz880
« Reply #32 on: June 17, 2003, 01:50:07 pm »
I have no problem in Win2K or Win98SE with MAMEWAH in the startup folder using an ArcadeVGA.
I have tried 640x288 and 640x480 in MAMEWAH but I leave my desktop resolution on 640x480 unless it changes itself occassionally.
« Reply #33 on: June 17, 2003, 01:57:52 pm »
Thanks for letting me know guys  :)
