Author Topic: Help with MAMEwah  (Read 2527 times)
WhiteComet
  • Last login:January 13, 2010, 04:22:21 pm
  • iD Project 2010
Help with MAMEwah
« on: September 03, 2008, 05:08:03 pm »
Ive contacted the forums and even the creator for help on a few points.... but with no reply...
is there anyone one here that knows alot about mameWAH the points I need are....
1. How to edit the buttons on the main mameWAH menu
2. To create a custom list (i.e. the roms in the order I want them to appear)
3. When you get to the bottom of the list, if you press down it takes you back to the first game
Any help appreciated........
H T T P : / / W W W . I N I T I A L D O N L I N E . C O M
Ginsu Victim
  • Comanche, OK -- USA
Re: Help with MAMEwah
« Reply #1 on: September 03, 2008, 05:24:51 pm »
First off, check http://wiki.arcadecontrols.com
1. Go to config and edit the CFG file.
2. Create a file in your emulator folder called emuname-1.ini (so for mame, call it mame-1.ini). Start mamewah and it will auto-populate the list. Then go to the game list options and filter it from there (the wiki will help with these steps)
3. Edit the mamewah.ini and set the wrap list option to 1
(This is all from memory. Check the wiki)
WhiteComet
  • iD Project 2010
« Reply #2 on: September 04, 2008, 04:14:30 am »
thanks alot.... ill give them all a try tonight
I think with this dont I import the games into the list the order I actually want them to appear?
Ginsu Victim
« Reply #3 on: September 04, 2008, 11:03:12 am »
I don't think you can do anything more than alphabetic order. The only way is to edit the .lst file by hand.
« Reply #4 on: September 04, 2008, 01:01:11 pm »
Sorry, if you PM'd me at MameWorld I haven't been on there (or here) for a little while...
Do you mean the controls? If so, see \mamewah\config\mamewah.cfg
Ginsu is right, in custom lists the order is simply alphabetical. Unless you set list_type to 'longest_played' or 'most_played' that is.
Again Ginsu is right, set wrap_list 1 in mamewah.ini.
Ginsu Victim
« Reply #5 on: September 04, 2008, 03:19:50 pm »
Ooooo, I never paid attention to this feature. I might make a custom list using this! Thanks!
WhiteComet
  • iD Project 2010
« Reply #6 on: September 05, 2008, 04:40:50 am »
So there is no way of making say a game begining with S appear on the list before a game begining with G??
Obviously I cant edit the zip files due to mame...  but can I wrtie a custom list? or is this not possible?
« Reply #7 on: September 05, 2008, 04:54:59 am »
I never paid attention to it either to be honest! I'm sure some people use it tho...
« Reply #8 on: September 05, 2008, 04:59:33 am »
You can edit the \files\xxx-?.lst file and set the order how you like but it is a bit of a pain to do this.
Why do you want to do this?
WhiteComet
  • iD Project 2010
« Reply #9 on: December 30, 2008, 11:54:58 am »
Hi... back again
Im having trouble creating a custom list....
The list contains about a dozen games, but I want them to appear in the order I set. I have tried the above but it changes the names to which it displays but doesnt change the order they appear in my list.
Anyone help?
« Last Edit: December 30, 2008, 12:09:44 pm by electronicdojo »
