Author Topic: williams comet system 9 power supply +5 volts reads 8 HELP  (Read 6061 times)
hawk007
  • Last login:April 23, 2012, 02:03:34 pm
« on: September 01, 2008, 12:43:58 pm »
hello everyone.....I am at a loss.  My power supply for my comet says all voltages are good but the 12 volts+ is a little low at 11.57 and the +5 is at 8 volts?  I have replaced both voltage regs. twice and the cap at c-10 and the bridge rectifier.  But still the same thing?  Please help!
Ken Layton
  • Guru
  • Technician
Re: williams comet system 9 power supply +5 volts reads 8 HELP
« Reply #1 on: September 02, 2008, 01:23:13 am »
Caps C7, C8, or C9 may be open. IC1 or the resistors around it may be bad.
hawk007
« Reply #2 on: September 02, 2008, 01:20:06 pm »
thanks sooo much i will replace thiose now and let you know how it goes.. Thanks soooo much
hawk007
« Reply #3 on: September 05, 2008, 09:38:03 pm »
o.k. i replaced all that stuff and a couple diodes as well and still high 5 volts. All resistors test good and voltage regs have been replaced three times now and still the same thing.  5 reads 8 or 9 and not 5 volts!  Help !!!!
Ken Layton
  • Guru
  • Technician
« Reply #4 on: September 06, 2008, 11:16:40 pm »
Doesn't this board use a mica insulator between the regulator transistor and the heat sink?
hawk007
« Reply #5 on: September 06, 2008, 11:27:30 pm »
some do but some have a nonconductive material gasket that isolates the reg from the heat sink but still transfers heat.  mine is not shorted or connected to the heat sink at all i checked that for continuity already.  Any other ideas for me?
hawk007
« Reply #6 on: September 07, 2008, 12:23:22 pm »
i am ordering a new rotten dog power supply for 75 bucks.  But someone must have encountered this problem before and fixed it and i want to fix this thing.  I will not surrender!
If any more ideas p-lease help!  I am not putting this to a landfill so i will hang onto it til we fix it and i will post what finally fixes the problem.
Thanks to everyone for your help
