Author Topic: [Buttons] Stuck quick disconnects and plastic nuts...  (Read 3482 times)
kagaden
  • Last login:September 10, 2022, 10:58:37 pm
« on: August 30, 2008, 02:58:49 am »
... DRIVE ME CRAAAAAZY!
I just installed new buttons on a showcase CP and am now doing so on my X-Arcade and WHY ON EARTH are some of these so STUBBORN to remove? I feel like my fingers are going to fall off. WTF.
Does anyone have tips on removing them so I can maintain my sanity?
kagaden
Re: [Buttons] Stuck quick disconnects and plastic nuts...
« Reply #1 on: August 30, 2008, 04:43:13 am »
I'm going to add e-clips to my list of hate...  :banghead:
scotthh
  • Last login:June 06, 2012, 10:03:42 pm
« Reply #2 on: August 30, 2008, 09:00:43 am »
Needle-nose pliers.
Put a small jeweler's screwdriver in and turn it to pry the e-clip open.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #3 on: August 30, 2008, 09:13:42 am »
I feel your pain. When I took the LED bayonets off all my lighted buttons, I could not get a single ground wire off the lights. I had to leave them all hooked up together and removed them all in one massive tangle.
Even needle-nose pliers wouldn't get the ground wires off them.
I'm scared I'm going to break them if I pull any harder.
mrjah
  • Last login:June 22, 2010, 07:40:54 pm
« Reply #4 on: August 30, 2008, 03:05:30 pm »
Yes! This is the way.
I used to use a pair of pliers to push the e-clip off, and catch it in a box so it wouldn't scoot under a workbench or otherwise disappear.  It worked well, but was complicated and annoying.  Then I looked closely at the clip and noticed those two nice little slots between the clip and the joystick handle.  Game over -- a little twist with a jeweler's screwdriver, and it's off and under control.
Wish I had noticed that a year ago.   :dunno
As for removing a quick disconnect, make sure you get the pliers' jaws down low enough to pull the entire disconnect off the terminal -- not just the wire or the colored sleeve.  Grab it too high, pull hard, and you might tear the thing apart.  Then you're right back at square one, but with a broken disconnect!
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #5 on: August 31, 2008, 05:07:17 am »
As for the plastic nuts, you need a button wrench.  It's a few dollars from Happ.
Best Kid iPad Apps
Ginsu Victim
« Reply #6 on: August 31, 2008, 10:45:26 am »
Well, plenty of better resellers have them. Divemaster on the BST boards could probably send you one cheapest.
shmokes
    • Jake Moses
« Reply #7 on: August 31, 2008, 02:33:34 pm »
Right . . . I just meant it's a Happ part (I think).  So anybody who sells Happ inventory probably sells it.  It's worth it's weight in gold.  Or, at least, it's certainly worth a few dollars.   ;D
Best Kid iPad Apps
Ginsu Victim
« Reply #8 on: August 31, 2008, 03:48:04 pm »
It's a life-saver. Especially since you can slide a screwdriver through the holes for the problem ones.
kagaden
« Reply #9 on: August 31, 2008, 04:54:12 pm »
Thanks for all the great ideas guys! It took me a lot of time, effort, fingernails, cursing, and sanity to get some of the super tight (and rusted) disconnects and nuts off the buttons. I ended up using a fork for the joysticks e-clips... but at least it's all done now!
I'll definitely pick up the proper tools for next time.  :cheers:
« Last Edit: August 31, 2008, 04:57:52 pm by kagaden »
