Author Topic: Re-doing control panel  (Read 3075 times)
Axe
  • Last login:April 16, 2010, 11:16:05 am
« on: August 27, 2008, 07:33:35 am »
A quick one here... my current project is a big ass showcase cab... CUrrent;y routed for 2 sticks and 4 buttons, i am planning to move the sticks wider apart.
I was considering cutting a new panel, but i am without a table saw or band saw... jigsawing a big ass panel, or doing it with a follower bit seems excessively blegh!
SO... since i am planning on  re-covering the top with malamine I was wondering if anyone has Bondo'd button holes to re-cut???  THe spot where the sticks will be going  will be fresh wood. as will the trak ball i am putting in the center.
Or am i being overly Lame-ass?
Just when you thought you were out of Mame???
THEY PULL YOU BACK IN!
  • Last login:December 02, 2025, 03:23:14 pm
Re: Re-doing control panel
« Reply #1 on: August 27, 2008, 07:40:37 am »
You may want to consider cutting some plugs out of scrap wood, and bondo-ing them into the holes.  (I'm just thinking maybe the holes would be too big for just straight bondo).
People here have done it before, it beats cutting out a whole new panel.
scotthh
  • Last login:June 06, 2012, 10:03:42 pm
« Reply #2 on: August 27, 2008, 10:47:39 am »
I bondo'd some security bolt holes with no problem at all. If it turns out the holes are too big, you can try this: I bondo'd damage on the side of the cabinet. I wound up using some self-adhesive fiberglass drywall joint tape to make a "form" for the bondo to fill. In the attached picture I already did some sanding and cut the t-molding slot. I did more sanding before priming and painting.
