Author Topic: Newbie: Second LED-Wiz not detected, except with LumAura?  (Read 2112 times)
opeo
  • Newbie
  • Last login:August 26, 2008, 01:03:13 pm
« on: August 26, 2008, 12:15:52 pm »
Hi all,
I have two LED-Wiz controllers hooked up and cannot access the second LED-Wiz using LEDBlinky or with the SDK demos. Both controllers are visible in the Device Manager as HIDs but every time I start up AnimationEditor the 'One or more LED-Wiz devices required by the Device/Port Input Map was not detected' message appears. When running SDK demos, the Active Device List button only shows a '1' in the left-most position.
The odd thing is, I am able to run an LWAX animation on the first controller using LEDBlinkyAnimationEditor (and SDK demos) and turn LEDs on/off on the second controller using LumAura panel that comes with LED-Wiz control panel.
Any help would be much appreciated.
Cheers,
opeo
arzoo
  • Robots WILL kill you.
    • LEDBlinky
Re: Newbie: Second LED-Wiz not detected, except with LumAura?
« Reply #1 on: September 08, 2008, 08:57:59 am »
Hi all,
Cheers,
opeo
Sorry for the delay getting back to you on this - somehow I missed this post. When you ordered the two LED-Wiz controllers, did you specify different Device IDs?
Robots will kill you.
Arcade Addiction
