Spyridon
Trade Count:
( +2)
Full Member
Offline
« on: August 24, 2008, 09:03:51 PM » |
Started working on restoring my Punch-Out!!. The game is in working condition, but will undergo the following treatment: Cap both monitors (bad foldover on the top of the bottom monitor) New side art (none on it currently) New CPO Paint or laminate the sides (if I can find the correct formica, I'll go that route otherwise I'll paint) Remove (or replace) scratches in the bezel Replace black t-molding with white t-molding Remove batteries from board Here is what I started with...
« Last Edit: July 10, 2009, 02:05:47 PM by Spyridon »
Logged
My current collection: After Burner II, Arkanoid^3, Asteroids Deluxe, Centipede, Donkey Kong, Front Line, Galaga, Gauntlet, Gorf, Gyruss, Multi-Williams, O'Boyles Arcade (Mame), Pac-man, Phoenix, Punch-Out!!, Satan's Hollow, Star Wars, Vanguard, War Gods
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #1 on: August 24, 2008, 09:15:00 PM » |
First step was to work on the control panel. Before and After   And now the details: The old overlay pulled off without too much trouble  I used Citristrip to take off the residual adhesive and then sandpaper to remove the rust spots.  After removing the rust spots, I hit it with a coat of metal primer  CPO came from Quarter Arcade   I used a dremel to shine up the carrige bolts and cleaned the buttons with some dish detergent and water
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #2 on: August 24, 2008, 09:18:06 PM » |
Logged
Chief Kicker - Nobody's perfect, including me. Fantastic body.
Trade Count:
( +11)
Full Member
Offline
« Reply #3 on: August 25, 2008, 06:10:40 AM » |
w00t Punchout! Good choice. CP looks great now.
Logged
Ginsu Victim
Trade Count:
( +7)
Full Member
Online
Comanche, OK -- USA
« Reply #4 on: August 25, 2008, 07:28:56 AM » |
Lookin' good!
Logged
robstraws
Trade Count:
( +1)
Full Member
Offline
« Reply #5 on: August 25, 2008, 08:30:11 AM » |
I almost bought one of these a few months back. Wish I had the guy only wanted 150 bucks. Nice Cp!
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #6 on: August 25, 2008, 01:05:50 PM » |
Moved the game into the garage today for painting. I checked a few stores and they didn't have black formica in stock, so I'm going to go with paint. Used bondo to fill in some holes:
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #7 on: August 25, 2008, 09:08:01 PM » |
Logged
2600
Trade Count:
( +5)
Full Member
Offline
I want my own arcade controls!
« Reply #8 on: August 26, 2008, 03:34:31 PM » |
When you get to the paint, could you do some really close shots? One possibly with a reflection of something basically touching the cabinet?
I got some samples of the laminate and for my PO, polished finish is the correct texture, but may be a bit too reflective.
Looking good so far, this is really motivating me to finish mine.
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #9 on: August 27, 2008, 03:28:54 PM » |
Sure.
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #10 on: August 27, 2008, 03:31:42 PM » |
Logged
2600
Trade Count:
( +5)
Full Member
Offline
« Reply #11 on: August 27, 2008, 07:24:51 PM » |
HVLP sprayer I assume or did you roll it? What brand paint and sheen did you end up choosing?
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #12 on: August 27, 2008, 10:45:03 PM » |
HVLP sprayer I assume or did you roll it? Yes, I used a HVLP sprayer. I don't think I can go back to rollers after using this.   What brand paint and sheen did you end up choosing?
I used Rustoleum satin black paint.
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #13 on: August 28, 2008, 09:12:06 PM » |
I used some 220 grit sandpaper to smooth out the surface then applied a second coat of black paint.    I'll look at it tomorrow when it is dry and determine if it needs a third or if it is ready to go. If it needs a third coat, I'll use some 600 grit sandpaper prior to the paint going on.
« Last Edit: August 29, 2008, 04:21:39 PM by Spyridon »
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #14 on: August 29, 2008, 04:25:00 PM » |
Logged
WunderCade
Hey Saint, wanna update my custom title? ;D
Trade Count:
( +1)
Full Member
Offline
« Reply #15 on: August 29, 2008, 07:17:41 PM » |
Nice looking paint job. I've always shied away from oil paints and have never used them through an HVLP sprayer. Did you use the same process as with the GORF blue, but instead used acetone to thin?
And finally, looking at the results on both cabs, can you compare and contrast how you think the oil paint out performs, result-wise.....the water-based paints? Thanks.
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #16 on: August 30, 2008, 06:41:23 AM » |
Nice looking paint job. I've always shied away from oil paints and have never used them through an HVLP sprayer. Did you use the same process as with the GORF blue, but instead used acetone to thin? Yes, same process but acetone instead of water to thin. Also, it took a lot less to thin it out than the latex paint, so you aren't diluting the color as much. And finally, looking at the results on both cabs, can you compare and contrast how you think the oil paint out performs, result-wise.....the water-based paints? Thanks.
The oil paint seems to go on smoother than the water based paints. It seems easier to get a perfectly smooth result. That being said, the results with the latex paint was still very good. The Rustoleum black paint seems to be a very good choice for black cabs and I would recommend going with it, however, I think for any other color I would still probably go with a latex paint because it is just so much easier to work with.
Logged
DarkKobold
Trade Count:
( 0)
Full Member
Offline
« Reply #17 on: August 30, 2008, 11:40:52 AM » |
Are you in Salt Lake City? I swear I just saw this machine for sale...
Logged
------------------------------------- My games: Tapper, Asteroids, Cocktail-MAME, Tron, ROTJ, Tempest, Star Wars (not working) My wants: Warlords Cocktail
Level42
Wiki Contributor
Trade Count:
( +5)
Full Member
Offline
A Suzo stick is a joy forever...
« Reply #18 on: August 31, 2008, 04:24:34 PM » |
Your threads inspired me to buy a compressor yesterday. Planning to do some spray painting for my cabs. Need to get a spray gun like that....
Logged
Ms.Pac Man, Video Pinball, Joust, Berzerk, Pleiads Cocktail, Galaxian, Centipede, Mario Bros., Star Wars Cockpit, Puckman (bootleg), Space Invaders, Power Drift, Asterock (Asteroids bootleg)
WunderCade
Trade Count:
( +1)
Full Member
Offline
« Reply #19 on: September 01, 2008, 08:27:34 PM » |
Great Andre...that means you'll be able to sandblast as well. Which is way cool for metal parts...can't beat it.
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #20 on: September 01, 2008, 08:58:18 PM » |
Nice. You won't be dissapointed. And like WunderCade said above, definitely look into sandblasting. (see my Gorf thread for details on the cabinet)
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #21 on: September 01, 2008, 08:58:43 PM » |
Nope. Pennsylvania.
Logged
Level42
Wiki Contributor
Trade Count:
( +5)
Full Member
Offline
« Reply #22 on: September 02, 2008, 10:22:50 AM » |
HA, I hadn't even thought about that yet !  I will need a good and compact sandblasting box though....don't have too much space for it :S
Logged
MaximRecoil
Trade Count:
( +1)
Full Member
Offline
« Reply #23 on: September 02, 2008, 11:28:03 AM » |
Nope. Pennsylvania.
That figures, PA is like Grand Central Station for Punch-Out machines. Do you have a closer picture of the underside of your KO button? It looks different than what I am used to seeing, but that may be an illusion from the low resolution picture. Nice job so far BTW; the paint and CPO look great.
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #24 on: September 02, 2008, 12:54:22 PM » |
That figures, PA is like Grand Central Station for Punch-Out machines. Yeah, I've seen several in PA. I wasn't even looking for one and this one showed up on Craigslist close to me for a great price. Couldn't pass it up. Do you have a closer picture of the underside of your KO button? It looks different than what I am used to seeing, but that may be an illusion from the low resolution picture. Probably just looks different from the photo. I'll take a close up and post it. Nice job so far BTW; the paint and CPO look great. Thanks for the compliments.
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #25 on: September 02, 2008, 08:51:28 PM » |
Here you go
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #26 on: September 02, 2008, 08:54:55 PM » |
Moved the game out of the garage and into the basement/gameroom. Started to reassemble the parts. Put the speakers back in place  Nintendo serial number plate back on the back  Grills back in place as well  I polished the marquee with Novus #1 and then put it back on the cab
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #27 on: September 02, 2008, 08:57:16 PM » |
I took the coin door apart in preparation for painting it.   On one of the coin reject buttons I'm missing the cover piece (middle item in picture below)  Anyone know where to get replacements for these?
Logged
MaximRecoil
Trade Count:
( +1)
Full Member
Offline
« Reply #28 on: September 02, 2008, 10:53:55 PM » |
Here you go Okay, thanks. Yeah, that's normal. The smaller picture made it look different, and I wondered if a new version of the KO button had been discovered.
Logged
jow
Trade Count:
( 0)
Full Member
Offline
« Reply #29 on: September 03, 2008, 02:35:53 PM » |
Looks good, ace.
Looking forward to the finished product.
Logged
WunderCade
Trade Count:
( +1)
Full Member
Offline
« Reply #30 on: September 03, 2008, 03:51:30 PM » |
Nice to see you made it over to the "other spot". Welcome Jow.
That black finish looks good Spyridon, how did the sides turn out close up?
« Last Edit: September 03, 2008, 03:54:02 PM by WunderCade »
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #31 on: September 03, 2008, 07:27:48 PM » |
Looks good, ace.
Hey Jow. So it took a Punch-Out!! restore to bring you over here. Welcome!
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #32 on: September 03, 2008, 07:29:01 PM » |
It game out pretty nice. It doesn't have that baked on hardened look that the original had, but I like it. I'll try and take a close up pic of the paint.
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #33 on: September 03, 2008, 07:32:20 PM » |
I used a drill with a wire wheel on it to strip the paint and rust off of the coin door. It's actually a faster process than when I used the sandblaster on the Gorf coin door. I was really surprised on how easy it was to strip down. Upper door:    Lower door:
Logged
Trade Count:
( +11)
Full Member
Offline
« Reply #34 on: September 04, 2008, 08:32:43 AM » |
Adapt a plastic storage bin... then when you're not using it you can store stuff in it. Double usage saves space.
Logged
jow
Trade Count:
( 0)
Full Member
Offline
« Reply #35 on: September 04, 2008, 10:48:44 AM » |
Looks good, ace.
Hey Jow. So it took a Punch-Out!! restore to bring you over here. Welcome! Thank you, good sir. It seems we are lacking in the resto thread dept "over there". I have been enjoying this one, and all the other one's on this board. My Punch-Out is currently not working, but once she's up and running, I too will resto it. Im def taking notes.
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #36 on: September 04, 2008, 01:49:42 PM » |
Do the cab restore now before you get it working. Once you get it working, you know you won't want to stop playing.
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #37 on: September 06, 2008, 11:18:39 AM » |
Painted the coin door using Rustoleum Textured black paint Here is a shot while still wet:  And when dry:  I'm really happy with the way it turned out. I also used a dremel with a wire wheel attachment to shine up the coin return cover. Here you can see the difference between the one I worked on (left) and the untouched one (right):  I also polished them when complete. Here are both of the finished products:
Logged
Spyridon
Trade Count:
( +2)
Full Member
Offline
« Reply #38 on: September 08, 2008, 07:40:09 AM » |
Coin door installed back into the cab:  I also added a lock to the back of the cab:   Since I already had two locks on the front coin doors that used the same key, I wanted the back door lock to also use the same key to open it. I followed the tutorial over at Arcade Restoration Workshop on how to key all the locks to same. I used an old lock I removed from a Robotron and I only needed to remove one tumbler to make it work  To end the weekend, I installed the white t-molding. Sure makes a big difference.
Logged
Trade Count:
( +11)
Full Member
Offline
« Reply #39 on: September 08, 2008, 09:05:25 AM » |
That is some fine work.
Logged
