Author Topic: mala layouts, not working  (Read 4135 times)
G1zm0
  • Last login:October 05, 2020, 06:57:58 am
  • cute by day, devil by night
« on: August 24, 2008, 08:09:46 pm »
hi ive tryed this layout http://forum.arcadecontrols.com/index.php?topic=69785.0 and a few others, and i cant get it to dispay any pictures or any gfx?
ive pointed the layout to layout f older, and it see it and i load it and nothing no gfx or any colours just black screen.
no matter what one i try i get same result
what am i doing wrong?
i point them to mr do's cab files
loadman
  • Moderator
    • MaLa
Re: mala layouts, not working
« Reply #1 on: August 24, 2008, 08:25:16 pm »
Yes that layout is nice.  I use it myself.
Have a look here:
http://wiki.arcadecontrols.com/wiki/Mala_Layout#F.A.Q.
Good Luck  ;)
shock_
  • Last login:January 30, 2020, 06:23:29 pm
  • In Brisbane, it's GMT+10 all the time.
« Reply #2 on: August 29, 2008, 06:00:42 am »
Hey
I built that layout - I've been meaning to getting around to tidying it up for resubmission to malafe.net.  (Loadman has been good about not nagging me :P )
If you're still having trouble let me know.
G1zm0
« Reply #3 on: August 31, 2008, 04:08:20 am »
hi, still no joy with layout, i put fonts in fonts folder, put vertical layout mll and pictures in mala root folder.
pointed define 1 to cabinet files.
i get the cab files and font but. where the game name is ment to highlight its just black, no txt there just a few numbers after where the txt should be like 6086.
there is no colour background, its just black.
the fonts are in the fonts folder, ive double checked this, im testing on vista
loadman
  • Moderator
    • MaLa
« Reply #4 on: August 31, 2008, 04:28:38 am »
Did you check the link I posted?
It would be that the folder you put the layour graphics in is not spelled right (Case sensitive) or
the setting in option-gu-layout (use layout name for directory names is not set.
Alternatively try have all the layout files just in the mala folder (not a subfolder) and switch that setting off
G1zm0
« Reply #5 on: August 31, 2008, 05:48:10 am »
i put it in the mala folder and read the instructions with the v54 file and on the wiki, it wasnt in a subfolder and it selected ok
just the few probs i mentioned
another thing not to do with this topic.
when i play the mala start up video and i have background music , it plays over the video? is there a way to get the music to start just after the video plays?
loadman
  • Moderator
    • MaLa
« Reply #6 on: August 31, 2008, 07:16:38 am »
Thanks for reporting. That one is already on my Bug List  ;)
loadman
  • Moderator
    • MaLa
« Reply #7 on: September 25, 2008, 04:22:07 am »
This bug has just been fixed and will be in the next release  :)
