Author Topic: PSU giving off voltages(is this cap bulging?)  (Read 1297 times)
AE35
  • Last login:January 18, 2022, 01:48:24 pm
  • That sure is a nice raygun!
« on: August 23, 2008, 05:25:58 pm »
Hey Guys!
I have a Hantarex US250(1989) that gives +26.8V on the +24V and +10.8V on the +12V.
The +5V is good.
Could I fix this, or would it be better to get an replacement!
Thanks,
Nicholas
« Last Edit: August 24, 2008, 08:53:49 am by AE35 »
grantspain
Re: PSU giving off voltages, can I fix that?
« Reply #1 on: August 24, 2008, 05:41:24 am »
i would expect you are not using the 24v so there is no load hence the high reading,the 12 is a little low and that could be a leaky cap on the output
beware those psu hold a lot of charge on the caps
AE35
« Reply #2 on: August 24, 2008, 08:44:00 am »
Thanks grantspain! I'll be careful!
Here's a picture..the 400v cap looks somewhat ready to go I think! or
is it just me?
grantspain
Re: PSU giving off voltages(is this cap bulging?)
« Reply #3 on: August 24, 2008, 09:04:38 am »
i reckon the 400v cap is o.k,thats the mains smoothing cap-usually if they go leaky you have start up problems
the most likely suspect will be direct on the 12v output line  and almost certainly will not look bad/bulging
AE35
« Reply #4 on: August 24, 2008, 10:06:18 am »
So, what do you think...since I have no idea what's on the 12V rail should I just shotgun shift all the caps except the 400v?
Or try to find a new one?
