January 09, 2026, 02:06:05 am
Ms. Pacman, Galaga, Pac-man all the same shell...any way to find out a list of dedicated Midway games that used the same cabinet design ?
Ok, here's the deal regarding these cabinets.........Pac Man and Galaxian are the exact same. Both are the same shape, size, andmade from the same materials. Both are made from plywood. Pac Man was apainted cabinet with silkscreened and stenciled art. The colors are stencilsand the black outlines are silkscreened onto it. Galaxian is a non paintedcabinet with vinyl silkscreened art applied to the entire surface of it.Early run Galaxian cabs used 25" monitors.Ms. Pac, Galaga, and Gaplus are almost the exact same cabinets with theexception of the coin door height and monitor placement position. Galaga'sare pressed board cabs while most Ms. Pac's are plywood. The extreme end ofthe Ms. Pac production run used particle board cabinets as well as allGaplus cabs are particle board. Early Ms. Pac's are painted the same waythat Pac Man cabs were while the later run Ms. Pac cabs are silkscreenedsticker. All Gaplus cabs are silkscreened sticker. Galaga's are sticker artover black melamine. Late run Galaga's did not use black laminated wood.Those are either bootleg cabs or someone elses restoration.Bosconian cabinets are similar in cut and style to Galaga/Ms. Pac/Gaplus butthe cabs are more shallow. They also had the monitors mounted horizontallyinstead of vertically. Bosconian's are made from white pressed board cabswith stickered art applied over them.Rally-X cabs are similar to Pac Man and Galaxian cabs except they are moreshallow as well. They are not the same as Bosconian's. The top of the cab isdifferent as well as the sloping angle of the front of the cab. Basically, aBosconian is a shallow Galaga and a Rally-X is a shallow Galaxian. Both areabout as shallow as Wizard of Wor.Burgertime cabinets are almost the same as Ms. Pac's. The Chefs hat can becut off to make the game almost exactly like a Ms. Pac. The real onlydifference is the upper back corners on a Burgertime slope down earlierwhile the Ms. Pac cab runs all the way back on the top angle before meetingwith the back door. Most people will never know the difference anyway.Burgertime cabs are made from plywood and use art applied the same way asPac Man's and early Ms. Pac Man's.I hope THIS clears up any problems.Brian
