Author Topic: Tron is ALIVE!!!! WAS: Tron help needed  (Read 3194 times)
shilmover
  • Last login:September 25, 2018, 12:36:59 am
« on: August 18, 2008, 11:12:27 pm »
So I picked up a Tron (see here: http://forum.arcadecontrols.com/index.php?topic=83470.0), but I wanted to keep the repairs separate.  Hope that is okay.
Here is what I know:
- I have power to all the lights, monitor.
- Game does not power up.  No sound.
- No corrosion on the Power Supply board.
- The PCB was repaired as some point.
- I disconnected the Purple wire, no difference.
- Fuses appear to be good (what is the best way to test them beyond visually?  Resistance?)
A few of questions...
1.  The yellow LED on the PCB, i know that flashes when ROMs are bad, but is on on when there is power to the board?
2.  Where can I check to see that voltage is getting to the PCB?
3.  Which of the 7 fuses is for the Power Supply?
I would like to try to fix it before I replace the Power Supply board.
« Last Edit: August 26, 2008, 11:56:19 am by shilmover »
My projects...
Finished:  Stargate (only 'cause I got it that way)
In progress:  Tron, 48-in-1 for School Auction, DKJr (currently a 60-in-1), Millipede, MAME System
shilmover
Re: Tron help needed
« Reply #1 on: August 19, 2008, 12:36:18 am »
Update.
Just checked the voltages.
+12V is good
+5 is reading +2.91V with the battery connected and +3.20V with the battery disconnected.
My projects...
Kevin Mullins
    • Me on Myspace
« Reply #2 on: August 19, 2008, 02:51:30 am »
Do you have the manual yet ?
TRON Manual
shilmover
« Reply #3 on: August 19, 2008, 03:23:08 am »
Yup.  Found one in the Cab.  :-)
There is definitely not enough voltage heading to the PCB.  Ordered a rebuild kit from Bob.
My projects...
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #4 on: August 19, 2008, 11:50:09 am »
Orange glow in the monitor tube neck?
NO MORE!!
shilmover
« Reply #5 on: August 19, 2008, 11:56:09 am »
Yup.
Monitor is definitely firing up, PCB is not.
Figured out last night that there is not enough voltage (+5V) coming to the PCB.  Ordered a PS rebuild kit from Bob.
My projects...
shilmover
« Reply #6 on: August 26, 2008, 03:22:22 am »
OK.
Came back from vacation and installed the Bob Roberts kit.  Still getting only +3.29V from the Power Supply.   :dizzy:
Any suggestions?
My projects...
shilmover
Re: Tron is ALIVE!!!! WAS: Tron help needed
« Reply #7 on: August 26, 2008, 11:57:27 am »
Woo Hoo!!!
Got Tron working this morning.
Monitor needs to be re-capped, but other than that, everything works on it.  My kids (and I) are so happy!   :D
Anyone have a list of the caps that need to be replaced on a Tron monitor?
My projects...
shardian
« Reply #8 on: August 26, 2008, 12:56:42 pm »
There is no such thing as a "Tron monitor". Look at the monitor Chassis and find the monitor type. If in doubt, post a pic of the chassis.
shilmover
« Reply #9 on: August 26, 2008, 01:19:05 pm »
My projects...
SirPeale
  • Green Mountain Man
« Reply #10 on: August 26, 2008, 01:21:05 pm »
It's a K4900.
shardian
« Reply #11 on: August 26, 2008, 01:22:40 pm »
Damn you peale. :)
shardian
« Reply #12 on: August 26, 2008, 01:24:17 pm »
You can order your cap kit from Bob Roberts for $5.
http://homearcade.org/BBBB/caps.html
shilmover
« Reply #13 on: August 26, 2008, 01:46:00 pm »
Damn!
I just placed an order with him and forgot that.
Anyone have a list of the caps from that kit?  I have a large number of caps sitting around.
My projects...
shardian
« Reply #14 on: August 26, 2008, 02:01:26 pm »
The cap list is in the manual:
http://home.earthlink.net/~rescuetron/docs/wg-49xx_manual.pdf
The bob roberts cap map is here:
shilmover
« Reply #15 on: August 26, 2008, 02:10:57 pm »
Sweet!  Thanks!
My projects...
