Author Topic: Centipede monitor replacement - Which monitor do I choose?  (Read 13006 times)
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
« on: August 18, 2008, 04:01:07 pm »
I'm a bit of a newb when it comes to Arcade monitor compatibility.  I have a Centipede that I'm restoring, going to replace the monitor.  It's a 19".  Not sure what monitor to replace it with though.
Just glancing at arcadeshop.com, http://www.arcadeshop.com/parts.htm#Monitors
Would the 19" Vision Pro Standard Resolution work?
Is there a better place to buy a monitor?  Is $179 for a 19" decent price?
Also, regarding installation, with the old monitor, does it HAVE to be discharged before removing it or is that just something that should be done for safety?  By the way, how do I discharge a monitor?  BYOAC talks about how important it is, but even the information listed in the wiki or the other monitor pages just says "consult a tv technician to do it".
With the new monitor, does it ship discharged or is it safe to handle?
Also, can I tell with the multimeter if a monitor has been discharged or not?
Sorry for all the nub questions but I'm quite new to the world of actual arcade monitors.
shred5
  • Last login:July 25, 2013, 04:37:40 pm
Re: Centipede monitor replacement - Which monitor do I choose?
« Reply #1 on: August 18, 2008, 04:41:12 pm »
http://www.happ.com/monitors/49132900.htm
135.00 right from happs.
The wells D7700 Monitor some people feel is better than the vision pro
http://www.wellsgardner.com/products/details.asp?iCat=3&iSubCat=44
Monitor should not be charged when shipped... They do slowly discharge over time anyway if left turned off.. but I would never go poking around in there without checking first. I do not discharge a monitor when installing or removing a monitor anyway. I only do when servicing a monitor.
You can test with a multimeter with a high voltage probe.
Dave
« Last Edit: August 18, 2008, 04:54:55 pm by shred5 »
Jakobud
« Reply #2 on: August 18, 2008, 05:43:32 pm »
Thanks for the help.
What exactly do I test with the multimeter to determine if the monitor has been discharged or not?  From what I read, you aren't supposed to touch the frame and any part of the 'electronics' at the same time.  So is that where u measure?  Just touch one end of the multimeter to the frame and the other one start poking around in the electronics?  Surely there must be some very specific spot I can test to determine how safe it is?
ahofle
    • Arcade Ambience Project
« Reply #3 on: August 18, 2008, 05:49:55 pm »
http://www.wikihow.com/Discharge-a-CRT-Monitor
Here's a quick tutorial on discharging with nothing more than a screwdriver and a wire with alligator clips.
http://www.instantarcade.com/discharge.php
« Last Edit: August 18, 2008, 05:54:15 pm by ahofle »
Level42
« Reply #4 on: August 18, 2008, 06:27:27 pm »
Why not give the G-07 another chance ? It's a good monitor once fixed.
Many problems can be fixed with a simple cap-kit.
Jakobud
« Reply #5 on: December 29, 2008, 12:45:30 pm »
Wow the Vision Pro 19" CGA Shelf Mount Monitor has gone from $135 -> $183.  Anyone know why the huge price jump since I started this topic back in August?
shred5
« Reply #6 on: December 29, 2008, 12:53:04 pm »
The tovis monitor which is the same as the happs monitor is also 189.00.... Used to be 159.00 I think....
http://www.betson.com/products/parts/JCM-44-4519-02
Anyways the happs 135.00 was a sale.
Dave
SirPeale
  • Green Mountain Man
« Reply #7 on: December 29, 2008, 12:59:16 pm »
Because it's not on sale anymore.
Don't worry...it should go back down.
