Author Topic: Trouble starting Mala with windows  (Read 2268 times)
austin_21b
  • Last login:April 22, 2009, 09:59:29 pm
« on: August 18, 2008, 10:45:48 am »
I want to start Mala with windows and shutdown the computer when I exit. I have the shutdown working correctly, but I can't get it to start with Windows. I found the box under GUI to checkmark "Start with windows", but when I select hit and hit okay to exit the options, I get an error saying Mala must quit. Check mala.exe.log for details. What is going on here? I also cant find the Mala.exe.log in my Mala folder.
Windows Vista home premium
Never mind, I put a shortcut in the startup folder and everything is working now.
« Last Edit: August 18, 2008, 02:54:40 pm by austin_21b »
loadman
  • Moderator
    • MaLa
Re: Trouble starting Mala with windows
« Reply #1 on: August 18, 2008, 07:31:23 pm »
Start with windows option attempts to put something in the windows registry.(The only bit of MaLa that touches the registry
They may not be compatible with Vista. I will have to check.
Yeah but as you have discovered you can put a shortcut in startup or run windows mala as the shell.
« Last Edit: August 19, 2008, 09:19:31 am by loadman »
csa3d
  • Will game for food
    • Galaxian Mame Conversion
« Reply #2 on: August 19, 2008, 08:22:14 am »
Note that if you are using a KeyWiz in conjunction with MALA, you will likely uncover another bug.  See this thread for more details.
-csa
