Author Topic: building an NES PC...only for NES emulation  (Read 6969 times)
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
« on: August 15, 2008, 02:44:31 pm »
i did a search for NES PC on here, but didnt turn up any results relating to what i want to do....however i'm sure someone has already asked this question before.  i actually may have myself a few years ago, but ive forgotten  ;D so here goes...
there are tons of people out there doing NES PC's...i googled....but most of those people want to use the NES PC for all kinds of extra crap.  i JUST want it to run NES emulation/roms.  so no complex video, or nintendo 64 cpu power requirements or anything like that, just simple nes emu.  with that in mind, i want to build this with as little cost as i can.  i already have most of the hardware, cept for the mini-itx board ill need to put in the NES.
so first of all, i have a few questions.  i went to newegg and found this board http://www.newegg.com/Product/Product.aspx?Item=N82E16813185103 .  its $25 after mail in rebate, and its got the cpu already built into the board (800mhz).  i went to this site http://www.instructables.com/id/Build-a-Nintendo-NES-PC/ and looked at everything this guy did...however he has a whole lot of other emu's that he's putting on there, so im hoping i can save some $$ by building a very low horsepower pc.  here's what ive got so far without having to spend money:
1.  NES w/ 2 controllers (hoping to use those...whether i mod or buy usb converted NES pads, i want to use the NES controllers)
2.  laptop hard drive
3.  laptop CD Rom drive
4.  extra case fans if necessary
what i think ill need:
1.  mini-itx mobo with cpu - $30
2.  IDE converter to plug drive into mobo - $10-15
3.  RAM - i need DDR 266 but i think the old laptop i have should have that, but if not - $20 or less
4.  external power brick - $??
so here are my questions:
1.  im assuming my 800mhz cpu/mobo is plenty for nes emulation right?
2.  OS - can i just use dos or will i run into driver issues with the controllers and such?
3.  i can probably find a tutorial on how to convert existing NES pads to usb, but ive never soldered anything in my life soooo....yeah....should i just buy some converted NES usb pads??
4.  any other suggestions before i embark on this venture??
any help would be greatly appreciated.  :cheers:
Re: building an NES PC...only for NES emulation
« Reply #1 on: August 15, 2008, 03:00:54 pm »
DOS is touchy at best with USB drivers.  Best to use Linux if you want USB.
Why a CD drive?  If you're going to use USB you can save a lot of space by using a cheap USB thumb drive instead of bulky optical drive.  You can save even more space if you decide to boot from one or use a compact flash-IDE adapter.  Doesn't cost much to do either and for something as simple as an NES emulator you could easily back the flash drive up for when it eventually wears out.  Make another copy, pop it in, and you're good.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: August 15, 2008, 03:21:42 pm »
800mhz is plenty for NES (SNES and Genesis, as well)
Linux or Windows. DOS is not recommended for USB devices.
There's tutorials online for converting pads. Also there are adapters
http://www.retrousb.com/index.php
I agree with Chad about the CF to IDE adapter. Forget a CD drive.
hulkster
« Reply #3 on: August 15, 2008, 03:22:41 pm »
thanks for the tips Chad.
ive never used or installed linux so i was kind of shying away from that....but im always open to trying  8)
CD drive because...um....well yeah.  i dont know why, i guess because i saw all the other tutorials talking about it.
about the hard drive...are you talking about booting to a usb flash drive?  i need the hard drive space for roms, screenshots, etc, and i dont have any flash drives big enough to hold all of that.  i know that space is somewhat of an issue, but if i can knock out the cd rom drive, then that gives me extra room.
and explain more about the compact flash-ide adapter...you lost me there. :dunno
Ginsu Victim
« Reply #4 on: August 15, 2008, 03:27:00 pm »
Pick up a compact flash and one of these
http://www.dealextreme.com/details.dx/sku.10310
« Reply #5 on: August 15, 2008, 03:28:43 pm »
Thumb drives of 8gig are easy to get now.  If you can come up with more than 8gig of NES ROMs and screenshots send the new discoveries our way.   :)
The tutorials with CD drives are old.  That's why they have CD drives.
hulkster
« Reply #6 on: August 15, 2008, 03:31:13 pm »
 :dizzy:  oh...yeah i guess i just assumed that the roms (even though they are only 20k or something) plus screenshots would be lots of hd space.  sorry for the retarded moment  :banghead:
so based on that....if i go to the CF route, how many gigs would be enough for OS, screens, FE, roms, etc etc??
Ginsu Victim
« Reply #7 on: August 15, 2008, 03:37:11 pm »
I have, so far as I know, the entire NES collection on one CD. You don't need much space at all.
hulkster
« Reply #8 on: August 15, 2008, 03:41:51 pm »
so thats around 700mb or so (minus dupes and crappy roms i wont play).  so that leaves screens and OS, plus drivers if i need them.  so....2-4gb?
are there drawbacks to using usb flash drives vs. cf ?  as in...speed?  im not talking about slowdown on playing the games, just booting up and such.
« Reply #9 on: August 15, 2008, 03:42:20 pm »
If you buy a new one you'll have trouble finding one that isn't many times the capacity you need.
hulkster
« Reply #10 on: August 15, 2008, 03:49:48 pm »
« Reply #11 on: August 15, 2008, 03:52:38 pm »
Or you can get a 4gig card for $4 more... hell the 2gig cards are the same price as the one you posted.
« Reply #12 on: August 15, 2008, 04:02:00 pm »
Because they aren't really available.  I've never actually seen one.  They made a splash whey they were supposedly released but I don't know anyone who was able to get one.
« Reply #13 on: August 15, 2008, 04:07:43 pm »
Have a schematic for using a real NES pad with that?  Or is that a miniUSB on the side?
hulkster
« Reply #14 on: August 15, 2008, 04:10:36 pm »
okay, so i get that 4gb card, with the adapter...and i'm looking at $20 total for the hard drive space.
what about my performance question?  any downside to using CF?  im not expecting lightning fast bootups, but i dont want it taking forever either.
« Reply #15 on: August 15, 2008, 04:13:12 pm »
I don't know but I'm sure that info is out there.  If some people are using them for MAME cabs I can't see them being a problem for an NES emulator.
Ginsu Victim
« Reply #16 on: August 15, 2008, 04:28:28 pm »
By your use of the words "an NES emulator", that leads me to believe you're in the group of people who call it N-E-S (en ee ess).
I've always called it the "Ness", and I'm not alone, but it seems from discussions elsewhere that I'm in the minority.
"Ness" just seems easier to me...
« Reply #17 on: August 15, 2008, 04:32:44 pm »
Or... proper written English generally dictates that "an" is used before acronyms that start with a soft consonant or a vowel.
Ginsu Victim
« Reply #18 on: August 15, 2008, 04:35:14 pm »
Right, which is how I came to that conclusion
« Reply #19 on: August 15, 2008, 04:38:17 pm »
So, since it is an acronym, that has no real bearing on how I would actually say it.   ;D
Though you are right I would say N-E-S.  I work in corporate software where people have whole conversations mostly in acronyms.   :banghead:
Ginsu Victim
« Reply #20 on: August 15, 2008, 04:43:10 pm »
I write how I speak, as I try to get my voice across through my typing. So I would write "a NES (ness)" because that's what I hear in my head. It's incorrect when written, but that's how my brain works.
I'm a lefty. We're just different...
« Reply #21 on: August 15, 2008, 04:43:43 pm »
Or not.  So am I.   ;D
Ginsu Victim
« Reply #22 on: August 15, 2008, 04:47:02 pm »
I just KNEW you would be when I said that.  :angry:
« Reply #23 on: August 15, 2008, 04:48:42 pm »
Heh.  I bet there are a lot of lefties here.  It's that kind of place.
Franco B
« Reply #24 on: August 15, 2008, 04:50:27 pm »
Ok, so there is N-E-S, NEZ, or NESS from what I have heard over the years. The latter can only remind me of one thing.
Ginsu Victim
« Reply #25 on: August 15, 2008, 04:59:03 pm »
What I thought, too. We're wired different, so we take things and wire them....different.
hulkster
« Reply #26 on: August 15, 2008, 05:12:29 pm »
okay then, so here's what i have so far (prices are rounded up):
1.  mobo - $30 after rebate
2.  4gb cf card - $15
3.  cf card to IDE adapter - $4
4.  vga to compositie video adapter - $5
5.  audio to composite audio adapter - $5???
6.  80 watt picoPSU - $30 (this is debatable...how else do i power my system?  can i rig up a laptop external power brick??)
massive88
« Reply #27 on: August 15, 2008, 05:27:18 pm »
Its an acronym for Nintendo Entertainment System, not a new, different word.
As long as you arent a person who says "L-O-L" or even worse "lawl" in real life though, carry on.   :laugh:
Ginsu Victim
« Reply #28 on: August 15, 2008, 05:38:28 pm »
I say both "en ee ess" and "ness", but I suppose I started calling "ness" because of Nester and Howard.
Ginsu Victim
« Reply #29 on: August 15, 2008, 05:41:51 pm »
No, definitely not one of those. Matter of fact, I never even use lol online.
SithMaster
« Reply #30 on: August 15, 2008, 06:45:25 pm »
I think you will need a desktop based power supply though I'm sure when the left handeds get around to it they will tell me how wrong I am.
Which vga to composite adapter are you looking at?  The problem I see is no support for Duck Hunt but I'll forgive you if there will be a picture filled post showing your work on this.
This reminds me of the Nomad link
edit- http://www.mini-box.com/picoPSU-120-power-kit
« Last Edit: August 15, 2008, 07:01:07 pm by SithMaster »
gonzo90017
« Reply #31 on: August 15, 2008, 07:34:00 pm »
If you wan't to save a little more money you can hook up your controllers to your pc using the DirectPad pro method along with using NTpad XP's drivers.
hulkster
« Reply #32 on: August 15, 2008, 10:21:00 pm »
thanks sithmaster....ive done a little more research and ive seen one build where a guy uses a 55watt psu...but its not one of the picoPSU's or anything.  its more like your standard ATX psu but more of a rectangle shape.  i might be able to find a slim psu from an old pc at work.  i saw those picoPSU's and the kit and everything, but they are just a little too expensive.  i know $50 isnt all that much, but every time i start talking about "another project" my wife gives me the evil eye followed by "you dont NEED it".   :blah:
anyway, i think ill just try to compare the price difference between the picoPSU and a standard PSU.
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
« Reply #33 on: August 15, 2008, 10:54:18 pm »
This is a Ness.
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
Blanka
« Reply #34 on: August 16, 2008, 02:18:53 am »
May I ask the question why?
Why put a system to emulate a system inside a system that does 30$ second hand that already does exactly that en does that extremely well?
Or do you want this:
http://hangarcatblues.blogspot.com/2007/06/nes-cartridge-sd-card-8-bit-heaven.html
So you can play zillions of unbought stuff?
Kangum
  • Last login:February 25, 2018, 07:46:20 am
« Reply #35 on: August 16, 2008, 02:48:46 am »
i have a nes to usb adapter and it works really well. I use the nes max with it  8). works decent although i think there is like 10 year old cheetos and ruffle chips stuck in it or something.  ;)
at least if you go the usb adapter route instead of build yourself you can swich from nes , nes max , nes advantage and back again. wich is pretty cool.
hulkster
« Reply #36 on: August 16, 2008, 08:01:57 am »
the same reason everyone in this forum builds an arcade machine to play zillions of unbought stuff when they can just play it on their pc with a keyboard....because they want to relive the experience as close to what they remember as a kid.  playing zelda with a 8 way joystick and push buttons just doesnt capture the old school feeling like actually playing on a tv with NES controllers.
for the record....i cant believe you asked that question in this forum of all places.   :dizzy:
so instead of doing the whole parellel cable hack that ive seen....just pony up and buy the usb adapters?
Mauzy
« Reply #37 on: August 16, 2008, 12:18:41 pm »
Are you going to add SNES support?
Before the argument starts, Ive always said "sness" or "super En EE Ess". None of this "Ess En EE ESS" crap...
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #38 on: August 16, 2008, 01:28:21 pm »
i had a parrallel hack at one point
It worked fine for older game controlers
No reason not to do it that way
Soldering is fun ^_^
Slow In Fast Out
hulkster
« Reply #39 on: August 16, 2008, 01:50:07 pm »
well speaking of that, ive been trying to figure out how i want to interface the controllers.  i could get one of those NES to usb adapter things...which would mean id have to not use the NES controller ports on the NES itself.  thats the more expensive option actually, cuz ill have to buy adapters which are $22 a pop.  id rather spend the money on the motherboard and other essential components since my budget is very limited.
the parallel hack ive seen and i guess i could do that.  ive seen it done two ways though.  one way is to actually make the end of the NES controller a parallel end.  the other way that ive seen is to wire the actual front ports on the NES to the parallel port on the mobo.  the only drawback to that is that ill have a parallel cable sorta sticking out the back of the NES.  that would however be the cheap option because i already have the parallel cable and wires and such.  ive never soldered though  :-\
finally on a different note, back to the psu ordeal.  im probably going to have to spend like $50 on the picoPSU kit (comes with power brick).  im open to other options though that dont cost as much.
