Author Topic: PS3 arcade sticks  (Read 19414 times)
Jest
  • Last login:August 26, 2009, 07:36:14 pm
PS3 arcade sticks
« on: August 14, 2008, 10:57:37 pm »
Does anyone know if it is possible to make or mod a stick/gamepad into working with a PS3?
  • Last login:Yesterday at 02:27:41 pm
Re: PS3 arcade sticks
« Reply #1 on: August 15, 2008, 07:30:04 am »
You mean like hacking a PS3 controller to make an arcade-style controller?  ;D
massive88
« Reply #2 on: August 15, 2008, 10:40:08 am »
Yes people know.
And for the inevitable follow up, yes it is possible.
And for the inevitable follow up, HarumaN can provide a hacked pad to do such, or you can research here and at the SRK forums, and dive in to try it yourself.
« Reply #3 on: August 15, 2008, 11:52:34 am »
Yes people know.
Quoted for truth!  8)
somunny
  • Is it hot in here?
« Reply #4 on: August 15, 2008, 09:58:32 pm »
Yes people know.
Well, get to it!  ;D  I'm ready when you are.
DJ_Izumi
  • Last login:November 04, 2023, 04:19:22 pm
« Reply #5 on: August 17, 2008, 06:22:14 pm »
AFAIK the PS3 will use any standard PC Generic HID game pad interface. (So USB PC game pads will work)
Also there is the PS2 -> PS3 adaptor so you could plug in any classic PS2 stick of your choice.
massive88
« Reply #6 on: August 19, 2008, 09:39:06 am »
Would that then include wired Xbox controllers?  Or are they not generic enough?
DJ_Izumi
« Reply #7 on: August 21, 2008, 04:54:56 am »
I'm pretty sure Xbox 1 controllers are propritary, or at least partially, as they are ALSO USB hubs with controllers connected.  (That's how the memory cards and other accessories dock into the Xbox controller)
Xbox 360 Controllers, as I recall, have a unique driver for the usual reasons and do not work as plug and play as any common PC game pad would, like anything you get from Logitech or other companies.  However I am not entirely sure, I have neither console honestly so I can't test it.
It does remind of a funny story, as I told a friend to use his wired 360 controller for PC emulation.
"It doesn't work?"
"Did you try it?"
"Yeah!  The lights don't come on."
"You mean the Xbox status lights didn't come on?  Maybe cause you connected it to a Dell Lattitude Laptop instead?  Did you try the driver settings to see if the controller responded or if it worked in game?"
"No..."
"Try it."
"It works!"
"How did you get that job reviewing games for IGN agian?"
Kajoq
  • Last login:June 14, 2024, 11:28:46 pm
« Reply #8 on: August 22, 2008, 02:30:31 am »
Hori Real Arcade Pro 3 is the answer you are looking for.  It doesn't get any better than an HRAP
http://www.play-asia.com/paOS-13-71-zl-49-en-15-real+arcade+pro+3-70-2sxw.html
« Reply #9 on: August 22, 2008, 07:25:09 am »
I would beg to differ...   it doesn't get any better than one you build yourself.
Kajoq
« Reply #10 on: August 22, 2008, 11:25:31 am »
I've built my own stick (and the control panel to my cab),  I still play on my HRAP1 the vast majority of the time if im playing consoles.  And you're not going to run into nearly as many issues with things like leads coming off the PCB and things of that nature with an HRAP.
Customs are sweet, but they're generally a lot more delicate
« Reply #11 on: August 22, 2008, 11:32:51 am »
I can pretty much guarantee that no leads will ever come off any PCB I hack (*unless you pull very hard on them).
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:October 08, 2024, 04:40:31 am
  • I am t3h GAY!!!
« Reply #12 on: August 22, 2008, 12:14:55 pm »
I don't much care for the Hori sticks, and I definitely agree with HarumaN.
Building your own FTW!
Also, I have never had any problems like leads coming off with any of the sticks I have built, and they have to endure some pretty hard times with my 4 children.
somunny
« Reply #13 on: August 22, 2008, 09:39:31 pm »
I'd wager that my XBOX 360 stick would hold me if I stood on it, no problem.  It's all how you build it.
Jest
« Reply #14 on: August 22, 2008, 11:52:12 pm »
I know a guy who knows a guy who imports sticks from Japan :P  I just don't have $150 to import the HRAP3 Amazon edition.  Then if I don't like the buttons/stick I don't have another $50 to replace them with Seimitsu or Sanwa parts.
I was just thinking of modding my HFS3 with an LS-33 and OBSF-30 but have decided to build a bar top cab instead.
atxscarface
  • Last login:February 16, 2024, 06:40:56 pm
« Reply #15 on: December 10, 2008, 01:07:36 pm »
I am wanting to start on a project to take the guts of a ps3 controller and put them into one the new upcoming Street Fighter IV arcade sticks. I love the arcade stick as it is but its not wireless much less bluetooth. I was thinking with the proper drivers and a bluetooth dongle this controller would work for a PC also. I have seen the wireless 360 arcade stick hosted by Endgaget, this is the same concept only with PS3 and using bluetooth.
Heres the research ive seen so far:
Heres the wireless 360 arcade stick from Endgaget: http://www.xbox360fanboy.com/2007/04/03/best-diy-arcade-stick-evar-its-wireless.
Heres the upcoming Street Fighter IV arcade stick I was planning on working with: http://www.gamestop.com/Catalog/ProductDetails.aspx?product_id=73045
And here is the information I found on using a PS3 controller wirelessly on a PC using bluetooth: http://boards.ign.com/Boards/Message.aspx?topic=163284350&brd=8269&start=163295180, there is a related video on youtube titled :
Ps3 SIXAXIS DualShock 3 On PC Laptop Bluetooth Wirelesly PS3 SIXAXIS on PC Bluetooth
Let me know if you guys think its possible and how hard it would be. I know of course some soldering will be needed but I was wondering if anyone had a wiring schematic or something I could go by?
« Reply #16 on: December 10, 2008, 01:32:45 pm »
It is possible (the wiring part, not sure about the bluetooth dongle)...  just be aware that soldering to the PS3 pcb can be difficult, depending on your level of soldering skill.
atxscarface
« Reply #17 on: December 10, 2008, 10:49:43 pm »
Where could I find someone to prepare the wiring for me? I mean if I can have at least the sixaxis wired with labeling I can complete the wiring to the arcade stick. How much would someone charge for this service?
« Reply #18 on: December 11, 2008, 08:31:15 am »
Funny you should ask...  ;D
I do controller hacks all the time for people.  Sending you a PM.
atxscarface
« Reply #19 on: December 12, 2008, 06:54:59 pm »
Sent you a PM let me know if you got it?
« Reply #20 on: December 12, 2008, 11:52:54 pm »
got it
atxscarface
« Reply #21 on: December 20, 2008, 09:56:30 pm »
What would be the best way in wiring multiple pcbs including the PS3 Sixaxis and a Wireless 360 controller. Would it be better to have the common signal wires meet on a set of multiple terminal strips or would it be best just to have each signal wire meet on the button switches themselves?
Gatsu
« Reply #22 on: December 28, 2008, 04:20:10 pm »
I've gotta go with HarumaN on this one as well. Building your own brings out an amazing sense of accomplishment. And no one can buy that same stick in a store. Its yours and unique.
I've built 1 for myself and 3 for others so far. It takes some learning, but in the end its so worth while.
And if you hit a snag, there's plenty of knowledgeable peeps here in the forum that are more than willing to help out.
Hunk_4TH
  • Last login:January 21, 2026, 09:48:13 pm
  • I DON'T ALLOW VANDALISM IN MY STOOOOOOOOOOORE!
« Reply #23 on: July 29, 2012, 05:30:37 pm »
I apologize for bumping such an old topic. But I have an old Sixaxis laying around that I would like to solder to in order to use my PS3 in my Mame cabinet. However it's nothing like the older PS controllers. Is there a guide on how to solder to the Sixaxis? I know there was an adapter floating around online but I can't seem to find those anymore.
« Reply #24 on: July 29, 2012, 05:34:11 pm »
Yeah...  don't solder that.  It's hard as crap.  Took me three hours to do one, and I hack controllers all the time.  Go find toodles over at shoryuken forums, he should be able to sell you an axisdapter.
Hunk_4TH
« Reply #25 on: July 29, 2012, 05:36:33 pm »
I thought so. I spend hours trying to find anything I could online but came up with nothing :( Thanks I'll do that :)
SNAAKE
  • Trade Count: (+29)
« Reply #26 on: August 02, 2012, 01:37:13 pm »
you can hack a ps1 controller and use ps1 to usb converters. those are like $5 on ebay.
Hunk_4TH
« Reply #27 on: August 05, 2012, 01:58:51 pm »
I was thinking about doing that too as I have plenty of PS1 pads! Thanks for the advice.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #28 on: August 06, 2012, 11:59:15 am »
How could you possibly want to Build Your Own Arcade Controls?
 ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D  ;D
Do they even have websites for that?
« Reply #29 on: August 06, 2012, 04:37:15 pm »
Just to throw it in the radar here. I do sell PS3 encoders for $22. Check the link in my sig. if interested.  :cheers:
SNAAKE
« Reply #30 on: August 09, 2012, 07:17:04 pm »
^ his encoder works great too. I have one because it was so cheap lol..I paid like 15 I think for one of the older model or whatever
« Last Edit: August 10, 2012, 01:31:26 am by SNAAKE »
Hunk_4TH
« Reply #31 on: August 09, 2012, 09:37:16 pm »
Sorry for the late reply. Thanks! I bookmarked that thread. I read your encoders have home button support? That's great! I'll definitely be looking into getting one of these off you :)
« Reply #32 on: August 10, 2012, 12:44:48 pm »
Yes, the ZD ReMatch does have a designated Home button. The Regular ZD Arcade board does not, but can still be used on a PS3.  8)
Hunk_4TH
« Reply #33 on: August 11, 2012, 12:59:31 am »
Awesome! Do you always have a few in stock?
« Reply #34 on: August 13, 2012, 03:24:25 pm »
Yep, I have been keeping a constant supply of them.
bootsector
  • Last login:December 29, 2018, 12:48:52 am
« Reply #35 on: August 16, 2012, 08:48:08 pm »
Hey guys!
There's another low cost encoder in the works: http://forum.arcadecontrols.com/index.php/topic,122023.0.html
It will support PS3 including home button.
Sent from my GT-P7510 using Tapatalk 2
rCadeGaming
  • Just call me Rob!
« Reply #36 on: November 22, 2012, 09:39:00 am »
MC Cthulhu. Encoder that works perfectly with PS3 and about a dozen other consoles.  Why does no one on this board ever mention it?
edekoning
« Reply #37 on: November 22, 2012, 09:57:20 am »
You could also opt for a PS360+. Although it seems to be in pre-order at the moment. Both it and the Cthulhu are sold at www.focusattack.com/categories/Joystick-Parts/PCBs/
