Author Topic: Any M1 users out there?  (Read 2370 times)
TheManuel
  • Last login:April 09, 2025, 10:13:43 pm
  • On and off hobbyist
« on: August 14, 2008, 04:32:06 pm »
I have incorporated M1 into my cab running MaLa and have a gamelist for it and everything but the problem is that M1 runs in an ugly DOS Windows.
The only front-end for it that I'm aware of is Bridge-M1 which is excellent but cannot be run from the command line.
Does anyone know of any cab-friendly front-ends for M1?
"The Manuel"
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: Any M1 users out there?
« Reply #1 on: August 14, 2008, 05:12:07 pm »
In Mala and using M1.exe, if you set the window state to minimized, you never see the Cmd Window.  Unlike using a hidden window state, this method allows you to press ESC to exit M1 and it also allows you to use the other keys to navigate to the other songs/games.
TheManuel
« Reply #2 on: August 14, 2008, 05:21:15 pm »
Hmm...
When I tried that, I'm pretty I was not able to switch from song to song for some reason but
I will certainly try again.  I meant to try both hidden and minimized but perhaps I skipped the hidden mode.
The only drawback there is not being able to see the names of the songs from the pre-made lists.  Here is where a front end would come in handy or even a MaLa plugin that simply shows the list of songs.
Thanks for you great tips as usual.
"The Manuel"
SGT
« Reply #3 on: August 14, 2008, 05:24:52 pm »
Yeah, the hidden mode doesn't work but the minimized does allow you to go the next song.  However I can see that you still need a gui for M1 to accomplish what you need.
TheManuel
« Reply #4 on: August 14, 2008, 06:14:57 pm »
I'll take that compromise until something shows up in the future.
"The Manuel"
Dazz
  • Last login:January 11, 2025, 07:43:39 am
  • HyperSpin Team
    • VPUniverse
« Reply #5 on: August 15, 2008, 10:12:56 am »
Have you checked out Bridge M1?  I've been messing around with it, excellent way to get sounds from games for ringtones or anything else.
TheManuel
« Reply #6 on: August 15, 2008, 10:23:25 am »
Yes.
Bridge M1 is the "de-facto" choice.
However, I was looking for a front-end that could be launched from MaLa and Bridge-M1 does not support command line operation.
Thanks.
"The Manuel"
