Author Topic: How do you designate an Ipac shift button?  (Read 1955 times)
austin_21b
  • Last login:April 22, 2009, 09:59:29 pm
« on: August 13, 2008, 02:58:37 pm »
I have an Ipac4 and have programmed my layout and all normal controls for my panel. However, I want to do shifted controls also. How can I change which button acts as the shift button using the WinIpac? Also, can the Ipac be used to simulate a mouse click?
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
Re: How do you designate an Ipac shift button?
« Reply #1 on: August 13, 2008, 03:05:07 pm »
In the panel on the left side of WinIPAC in the key assignment mode, there are a pair of radio buttons for normal keys and shifted keys. Select Shifted and then you can program the key you'd like to use.
I don't believe the IPAC can do mouse buttons.
« Last Edit: August 13, 2008, 03:06:39 pm by st »
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: August 13, 2008, 03:10:25 pm »
In table view, the upper left shows SHIFT 1. This is where you change your shift button:
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #3 on: August 13, 2008, 05:18:30 pm »
The I-PAC is a keyboard device so does not emulate mouse buttons but one option is to use the Mousekeys feature in Windows. This is mentioned in the Windows Help file.
Andy
Ummon
  • Trade Count: (+13)
« Reply #4 on: August 16, 2008, 08:38:23 pm »
Hmmm. For some reason SlikStik wired the middle trackball (mouse) button to 'L', though it could have been wired to the TB controller.
Yo. Chocolate.
Stephen Hawking
