Author Topic: FS 16 Coin mechs multi coin acceptor Canadian (I think)  (Read 1381 times)
stan2323
  • Last login:January 13, 2023, 06:05:19 pm
  • Major Retired USS Enterprise Commanding
    • My home page
« on: August 12, 2008, 12:22:54 pm »
I have 16 coin acceptors from I think vending machines.  See the pictures.  I tested them with a US quarter and the number on the tape is the number of times the quarter went through as it should.  Some went through with a bit of a shake but I did not count those.  I tried a US nickel and dime but they would not go through.  I believe they are set to accept Canadian coins of different types.  They have slots on the end for different switches and a couple still have the multi switch attached.  They are in OK shape with some light rust and a couple has some corrosion.  They may be easily cleaned up and lubed for use.  These are larger than the standard coin mechs in arcade games.  I think they are for vending machines but if you have a vending machine coin door they would work in an arcade.
Price is $8 plus shipping.  They weigh 35 pounds so shipping could be expensive.  If someone wants to do a local pick up that would be best.  Must take all.
Stan
Careful what you wish for you may get it!!
There are 10 kind of people in the world those that understand binary and those that do not!!
