Author Topic: Mame-adult-games-filter  (Read 8172 times)
clok
  • Last login:April 03, 2018, 10:58:39 pm
  • I can play PacMan till the screen splits!
« on: June 09, 2003, 11:53:12 am »
What would you guys suggest for hideing the Adult games in MAME. Looks like I may have some underage players on my machine soon. I would like to make the Adult games unavailable, but I do not want it so I cant play them (I always liked Qix, and the adult varations just give a slightly better goal). 2 Icons to start mame is what Im looking at ( 2 installs) one for everything, and oen with the filter. Im looking for Ideas on what you have done, what you would suggest, or what works.
thanks
Clok
Oh I did search, got one Hit on MameWah (will Look into it) still looking for advice or thougths)
« Last Edit: June 09, 2003, 11:54:49 am by clok »
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Mame-adult-games-filter
« Reply #1 on: June 09, 2003, 11:57:58 am »
« Reply #2 on: June 09, 2003, 01:36:13 pm »
You can filter out the adult games using MAMEWAH (+ CatVer), although atm it is not possible to entirely prevent people from viewing such games (someone could switch games list and see said games).  I may well add something to prevent this in a future version.
I believe most other FE's can filter by this as well - give them a look :)
Hoagie_one
  • Um....whats a cabinet
« Reply #3 on: June 09, 2003, 02:24:48 pm »
a password lock would be cool.  Maybe one where youhave to enter a combinations of buttons or joystick moves to unlock the adult games, and to lock them again
CM
  • Last login:January 02, 2012, 08:59:17 pm
  • The internet?!? Is that thing still around?
« Reply #4 on: June 09, 2003, 02:40:03 pm »
Be careful!  You are aware that an adult filter will significantly cut down on all those glorious mahjong games!   You may only be left with about a thousand mahjong titles to choose from!   ;)
_Iz-
  • Last login:February 11, 2026, 11:54:26 pm
  • Time to coin up!
« Reply #5 on: June 09, 2003, 03:06:26 pm »
I believe emuloader has a parental lock.
anthony691
  • Last login:January 29, 2016, 03:10:23 pm
    • Lightgun.tk
« Reply #6 on: June 09, 2003, 03:31:14 pm »
Couldn't he just change the list switch be a button he doesn't have? That way he could easily switch it back, but no underage could. This filter is GOOD! (I recommend using MAMEWAH for this!)
Visit my MAME lightgun site:
http://www.lightgun.tk
_Iz-
  • Time to coin up!
« Reply #7 on: June 09, 2003, 03:48:55 pm »
There's an easy way to do this with any frontend that supports multiple rom paths. Move all adult roms to a separate folder. Make 2 copies of your chosen front end and have them in 2 separate folders. One copy will have the main roms as its only rom path, configure the other copy to search the main rompath and the adult rompath. Give the kids a shortcut to the "censored" frontend .exe and stash a shortcut to the "uncensored" frontend .exe for yourself.
« Reply #8 on: June 09, 2003, 06:03:50 pm »
Very true...but I personally would find this a pain since you need to know which ROMs are adult in the first place, and then manually move them.  Of course each time a new MAME comes out you need to check for new adult games.  The danger is it wouldn't be hard to miss one...
« Reply #9 on: June 09, 2003, 06:05:22 pm »
Good idea (I forgot about the customisable keys myself, lol!).
_Iz-
  • Time to coin up!
« Reply #10 on: June 09, 2003, 06:08:27 pm »
I'd just use Mame Content Manager and Catlist. It will move them for you AFAIK. Even if it won't move them you definitely can have it change the extension on the naughty roms, then just manually move the ones with the changed extension (sort by type, then drag and drop) and flip them all back to .zip from the commandline in one shot.
« Last Edit: June 09, 2003, 06:10:25 pm by _Iz- »
« Reply #11 on: June 09, 2003, 07:02:34 pm »
Aahh I see...sorry I thought you meant just doing-it-yourself :)
clok
« Reply #12 on: June 10, 2003, 04:04:25 pm »
lots of good suggestions, going to look inot a few, many thanks.
CLok
mameplaya
  • Last login:February 20, 2005, 10:17:20 pm
  • Good. Bad. I'm the one with the gun.
« Reply #13 on: June 11, 2003, 05:55:57 am »
just let the kids play the games! i am sure they will learn more about sex from that game then from what most parents "teach" their kids.
parents: they suck.  :'(
