Author Topic: WG 25K5501 Sync Issue  (Read 2361 times)
ToplessZ
  • Last login:December 08, 2018, 09:55:34 pm
« on: August 10, 2008, 02:56:54 pm »
I have a WG 25K5501 in a 1987 Quarterback cab.  Its works fine with the quarterback PCB(NOT jamma), but it wont sync with any jamma boards?
The quarterback PCB uses both Neg Horiz&Vert inputs seperately.  I tried to use each individually and together with the sync on the jamma harness and no luck.
How do you sync to this monitor with a standard res jamma board?
Jamma is negative composite isnt it?
I have a 4583 Vid Sync Sep IC, not sure how to use it though...
ToplessZ
Re: WG 25K5501 Sync Issue
« Reply #1 on: August 10, 2008, 03:02:23 pm »
Also, I have a bootleg Ms. Pac board that has a jamma adapter on it that works fine connected to this monitor using the jamma sync connected to just the neg horz sync.
ToplessZ
« Reply #2 on: August 11, 2008, 11:29:38 am »
Could this be a low res monitor?  KLOV says that quarterback is a standard res, but it seems only games made before 1990 and non jamma will work in it??
grantspain
« Reply #3 on: August 11, 2008, 11:35:44 am »
standard res is low res(15khz)
do you have photos of your wiring and the problem you are getting
Kevin Mullins
    • Me on Myspace
« Reply #4 on: August 11, 2008, 05:04:38 pm »
Agreed .... the only ones lower than that are made by Crayola.
ToplessZ
« Reply #5 on: August 11, 2008, 08:04:55 pm »
Well thats good to know,  then theres still hope to get this to work! 8)
