Author Topic: Plexi or Lexan - where can i get a 25x27 cut for cheap online or local?  (Read 1822 times)
scrapple
  • Last login:June 07, 2013, 12:38:38 pm
Where are you guys getting your stuff?
Vash
  • Last login:November 22, 2016, 03:31:09 pm
Re: Plexi or Lexan - where can i get a 25x27 cut for cheap online or local?
« Reply #1 on: August 07, 2008, 10:21:37 pm »
I got mine cut at Ace Hardware.  Mine actually had a fairly steep curve that the guys working there cut perfectly.  If you're looking for smoked plexiglass though, you'll probably have to order it online.  I picked mine up at e-street plastics, but I'm still waiting on the delivery (and potentially for it to ship at all).
extendedplayarcade
  • The Games You Crave
    • Extended Play Arcade
« Reply #2 on: August 07, 2008, 10:34:37 pm »
Lexan is stronger than Plexiglass.  Also Lexan is easier to polish out scratches with blue magic.  Plexiglass is cheaper though.
I usually order my lexan from mcmaster carr book but I know lowes and home depot have an area.
But it is hard to find an employee at those stores that can cut it correctly.  You can get a scoring knife for lexan and plexi glass and cut it yourself.
You score it with a straight edge (i know i am spelling score wrong but to lazy to spell check) and then hold it along a straight edge and litterally bend/snap it over the straight edge.  It works best if you score it then flip it over and bend/snap it over the straight edge.
For rounded corners you are going to need a router.
Hope that helps
Brent
www.extendedplayarcade.com
somunny
  • Is it hot in here?
« Reply #3 on: August 07, 2008, 11:58:43 pm »
Check your yellow pages (or online) for plastic suppliers.  I found a local shop that cuts stuff for me on the cheap.
skottc
  • Newbie
  • Last login:November 14, 2008, 09:51:20 am
« Reply #4 on: August 08, 2008, 08:51:08 am »
custom Lexan & Plexiglass in Southern California.
www.ocip.com
