Author Topic: Vertical cab nightmares :(  (Read 6681 times)
nullb0y
  • Slow In Fast Out
    • WAT Racing
« on: August 06, 2008, 09:35:36 am »
So, ive been fixing the vertical cabinet,
I upgraded the ram and video card
But the ati radeon 9200 se doesnt seem to want to rotate the monitor with software
I can use gameex but the nagging about registered version is anoying and looks bad, plus i dont have $$ to register lol
I just plan on using mame on this cabinet
I am using a minipac
What front ends are out there that will rotate the screen?
Im loosing my mind trying to get mamewah to rotate the screen
any help would be great
thanks
null
Computer specs:
Intel pentium 3 1ghz
133mhz ram (1x512 + 2x128)
Ati pci 9200 se dual monitor card
Windows xp
mini-pac
trackball and buttons
I want a nice clean FE that i can put skins on
« Last Edit: August 06, 2008, 03:00:07 pm by nullb0y »
Slow In Fast Out
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: Vertical cab nightmares :(
« Reply #1 on: August 06, 2008, 09:46:24 am »
AtomicFE and Mala  will work.
Mamewah too i think.
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #2 on: August 06, 2008, 10:00:49 am »
MultiFE support vertical resoulutions too.
Mamewah can only rotate if Windows desktop is set to vertical mode too and created a speciel skin. But it DOES work, since I have seen vertical skins too.
Goz
  • KOTA
« Reply #3 on: August 06, 2008, 10:03:37 am »
The Catylist drivers for the ATI card should have the option to rotate the display. It really should be as simple as right clicking the diamond icon by the clock and rotating. If it doesn't work then you likely have a driver issue.
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #4 on: August 06, 2008, 10:08:20 am »
thats what ive been doing, i installed the proper drivers and such, but it doesnt work, so i gave up
atomic fe looks nice, im going to try that one out for now
it rotates properly too ^_^
Slow In Fast Out
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #5 on: August 06, 2008, 02:56:49 pm »
okay, atomic fe keeps freezing up on me or going to just a black screen when i load it....
Next :(
Slow In Fast Out
youki
    • Atomic Front End
« Reply #6 on: August 06, 2008, 03:38:05 pm »
It is just because you didn't install the video codec.
In Atomic folder there is a file codec_tscc.Exe , run it once.  Then it will work.
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #7 on: August 06, 2008, 09:53:08 pm »
Yeah, it was that and i got the softrotate working by reinstaling the drivers a 3rd time
after i rotated the screen with ati i needed it on horizontal 600x800 mode
So its working now and there are no video problems
But how do i filter to only vertical games?
I dont even need the horizontal ones on there but going 1x1 is going to take some time
also, how do i remove the nag screens with your front end?
« Last Edit: August 06, 2008, 10:45:04 pm by nullb0y »
Slow In Fast Out
youki
    • Atomic Front End
« Reply #8 on: August 07, 2008, 02:57:00 am »
With Atomic and Mame , you don't need to rotate with Ati.
You can simply rotate Atomic by choosing  Orientation "Vertical ->" or "Vertical <-" on the general tab of Atomic manager.
Then on the "folder" tab, at the end of the field "default emulator" , add  -rol  or -ror  . For instance to have something like :
c:\mame\mame.exe -ror
Then all your game should be rotated when you run them.
If you want filter vertical game  (despite the fact that with -rol you can play also horizontal game rotated).
You simple solution is to put only vertical game in your folder.
But you can also create gamelist that contains only vertical game.
To do that game list, you can use External tool like Romlister (i think there is thread somewhere here about it).
Or use build in gamelist creator in AtomicManager.
To know how it work , i strongly suggest you do step by step  the "simple tutorial" i created, you can find it on Documentation page of my website.
After that you should have good base to understand and use Atomic. and create your config as you want.
Don't forget to install the last patch of atomic , if you didn't already do.
I have a official support forum in english here :   http://spaceinvaders.7.forumer.com/
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #9 on: August 07, 2008, 10:41:47 am »
Well, i used a few outdated movers to remove the horizontal games and i removed quiz and dupes etc....
but the movers i used were .90 and .115 and my set is .126 lol
i keep finding games i dont want
Slow In Fast Out
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
« Reply #10 on: August 08, 2008, 10:05:06 am »
wow, I've suggested romlister 3 times today... I'm on a self promotion frenzy!
http://www.waste.org/~winkles/ROMLister
Use this tool.  The idea is not to have ALL the mame roms on your machine and weed them out by hand, instead, find the roms that will play on your machine (with your given set of controls/monitor orientation) and the ones you're interested in playing (filter out the quiz and mahjongers) and bring only those games into your mame folder.  Life is much nicer that way.
-jeff!
loadman
    • MaLa
« Reply #11 on: August 09, 2008, 01:21:32 am »
RomLister is Super Kewl   :P
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
« Reply #12 on: August 09, 2008, 08:28:34 am »
I still use Sort Info because I can make a batch file that will actually move the unwanted roms to a different folder.  Will romlister do the same?
Thanks...
NOP
    • winterMAME
« Reply #13 on: August 09, 2008, 09:27:47 am »
yes, we'll, the inverse of that.
You can use romlister to make a batch file to move the roms you *want* to another folder.  ;)
southpaw13
  • Whatever!
« Reply #14 on: August 09, 2008, 05:28:28 pm »
Awesome....time to update....
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #15 on: August 11, 2008, 10:12:56 pm »
thats pretty cool ill give rom lister a try
So, Current issue: atomic fe and mame are making sound lagg
I tried a defrag
Im not maxing out the cpu video card or ram
Any ideas?
Slow In Fast Out
NOP
    • winterMAME
« Reply #16 on: August 11, 2008, 11:08:35 pm »
Probably a directdraw/d3d issue and perhaps syncing to scanlines option that need some adjustment.
there was a nice thread about stuttering audio somewhere here.  I had it really bad on my machine (couldn't even play galaga) but all it was turned out to be some video option.  MAME now syncs the audio with the video for better accuracy in emulation.
This is from one of my mame.ini files, which I believe works fine (I'm not actually on my machine-this is from a backup)
Code: [Select]
# VIDEO OPTIONS
video                   ddraw
numscreens                1
window                  1
maximize                1
keepaspect              1
prescale                  1
effect                  none
pause_brightness        0.65
waitvsync               0
syncrefresh             0
I have an arcadeVGA pumping to an actual arcade monitor though-your experience may be different.
I can post my entire ini file if you want it.
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #17 on: August 12, 2008, 10:36:20 am »
Thanks, i will give that a try and let you guys know how it works out
Slow In Fast Out
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #18 on: August 12, 2008, 12:26:11 pm »
i don't have a mame.ini.....
also it is now using 100% of my processor (swapped in a slightly slower p3 1ghz>933mhz)
« Last Edit: August 12, 2008, 12:32:06 pm by nullb0y »
Slow In Fast Out
NOP
    • winterMAME
« Reply #19 on: August 12, 2008, 01:19:07 pm »
run mame -createconfig to have it make one.
These options can also be set on a per game basis, by looking in the ini folder and then it's <gamename>.ini
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #20 on: August 12, 2008, 08:26:34 pm »
i think the games to blame are just to much for a 933mhz proc
Im going to try swapping the 1ghz back in and see if she boots
Slow In Fast Out
NOP
    • winterMAME
« Reply #21 on: August 12, 2008, 09:10:13 pm »
yeah, that could certainly be the deal.
As I mentioned, I couldn't even run galaga without stuttering, and pretty much any pentium class CPU should be able to pull that off, so it was absolutely something else that was wonky.  Try any of the classics-they should work without sound skipping, even on that class of CPU.
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #22 on: August 13, 2008, 12:35:01 am »
the galaga 88' or w/e has skipping audio....
Thats pretty sad
But ill try what you said... mabey tomorow
Slow In Fast Out
gonzo90017
« Reply #23 on: August 13, 2008, 01:17:38 am »
Just try an older version of mame.
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #24 on: August 13, 2008, 10:25:15 am »
ive also gotta gothrough my games list
some of this stuff is showing up in atomic fe that shouldnt be there
(horizontals and roms i dont have)
Okay, i tried changing the video options
That didnt do anything it almost seems worse
I might just try putting a cheap yet newer and faster pc in there
Newegg had a sempron 3000+ for like $45
« Last Edit: August 13, 2008, 10:32:45 am by nullb0y »
Slow In Fast Out
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #25 on: August 13, 2008, 11:03:09 am »
how old? lol
my rom set is .126
Slow In Fast Out
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #26 on: August 13, 2008, 11:37:01 am »
Okay, got a blue screen of death.....
wow.....
definately going to upgrade the computer
okay i turned down my audio sampleing to 12000 from 48000
there isnt as much lagg but the games that were the problem  now just crash... no problems with other games lol
« Last Edit: August 13, 2008, 11:59:47 am by nullb0y »
Slow In Fast Out
M.Lanza
  • Last login:October 09, 2015, 09:51:03 am
« Reply #27 on: August 13, 2008, 08:08:54 pm »
I could run most games fine using mame .102 on a celeron 1.2ghz based pc
with a 4400 audio sampling rate and no frameskip.
Your 1ghz pentium 3 should be enough to run most vertical games.
Trample the weak, hurdle the dead
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #28 on: August 13, 2008, 10:41:29 pm »
so will the .126 set work with an old mame set?
Slow In Fast Out
M.Lanza
« Reply #29 on: August 13, 2008, 11:07:44 pm »
You can use clrmamepro to convert your romset.
gonzo90017
« Reply #30 on: August 14, 2008, 02:23:25 am »
Most roms should work. There will be some that don't. You could try FastMame 0.98. It's an optimized version of mame.
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #31 on: August 14, 2008, 11:45:10 am »
Well, i managed to get mame to do several BSOD
Looks like shes overheating at times
i might try an old set or fast mame
(i only need vert roms and not all of them)
part of the problem appears to be the video card/drivers....
mabey it doesnt like flipping and mame....
or mabey its because it just loosely sits there
the heatsink is warm to the touch
Ill probably throw a fan in there
« Last Edit: August 14, 2008, 11:57:43 am by nullb0y »
Slow In Fast Out
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #32 on: August 17, 2008, 09:32:59 am »
I worked out the crashing issues
So, now onto the other things
Atomic FE quits out of game and FE some times when using player 1 and 2 start to exit a game
Gotta get that fixed
Sound still skips in some games
I will probably live with that
Slow In Fast Out
youki
    • Atomic Front End
« Reply #33 on: August 17, 2008, 12:17:45 pm »
I think it is because you press to long your keys.  or you have some kind of ghost key.
To workaround that, you can simply , assign a different key to exit AtomicFe (with AtomicKey.exe).
Or you can set a password on exit in AtomicFe (with AtomicManager).
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #34 on: August 17, 2008, 12:21:45 pm »
good point
Its a minipac so no ghost key
but you have to hold 1 for a second then tap 2
and half the time im staring at windows lol
Slow In Fast Out
gonzo90017
« Reply #35 on: August 17, 2008, 02:07:52 pm »
Did you try an older version of mame for your skipping problem?
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #36 on: August 19, 2008, 06:31:26 pm »
It turns out that im having a processor problem
I run my boot disc processor test and almost immediately it crashes
Some games run fine - ms pacman
But i load anything else or too many games and it crashes
The audio slow down is specific to 1 or 2 games now but those are pulling on the cpu way to much and i get video lagg so its expected
I need to replace the processor/motherboard
I just dont have the $$ for anything decent right now
« Last Edit: August 19, 2008, 06:37:37 pm by nullb0y »
Slow In Fast Out
youki
    • Atomic Front End
« Reply #37 on: August 20, 2008, 04:20:16 am »
Did you overclocked your processor?
Try to reduce the cpu clock , it should possible somewhere in your bios.
Just to see if the problem occurs less often or not.
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #38 on: August 20, 2008, 05:38:59 am »
IT says the clock on the FSB is 133mhz (forced by ram?)
Slow In Fast Out
Ummon
  • Trade Count: (+13)
« Reply #39 on: August 20, 2008, 05:11:48 pm »
.....it means it's SLOW. Skip back to mame .68 at least - or upgrade your computer.
Yo. Chocolate.
Stephen Hawking
