Author Topic: Mounting an I-PAC  (Read 4056 times)
Dan
  • Last login:February 09, 2010, 11:52:34 pm
Mounting an I-PAC
« on: March 12, 2002, 11:56:08 pm »
What's the simplest way to mount an I-PAC to wood?  Those holes are really small!  I can't find any screws that'll fit.  Any ideas?
Thanks,
Dan
lo_cash
  • Last login:October 05, 2004, 12:59:55 pm
    • Built4Mame.com
Re: Mounting an I-PAC
« Reply #1 on: March 13, 2002, 05:48:26 am »
I went through my drill bits to find a drill slightly bigger than the existing hole.  I used this to open up the holes.  Then using (4) 4-40 x 1" screws and bolts and (4) 1/2" long nylon spacers I mounted it to the inside bottom of my control panel.  The bottom of my panel is masonite (about 3/16" thick) if you are using something different you will probably need londer screws.
Good luck.
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
« Reply #2 on: March 13, 2002, 06:04:16 am »
I used 3/4" #4 wood screws, and 1/4" aluminum spacers.  I did not have to enlarge the holes at all.
American Laser Games Wrapper
O2em Rom Utility
gnateye
« Reply #3 on: March 13, 2002, 11:10:08 am »
i bought a pcb mounting kit for like 2$ from happs.
Peeper
  • Last login:February 10, 2003, 05:46:43 pm
« Reply #4 on: March 13, 2002, 11:44:18 am »
I bought some insulated standoffs from Radio Shack for about $1.50. The screws are the perfect size! I screwed the standoff to the I-PAc, placed the Ipac on the board and marked the positions of each standoff on the board. Then I just hotglued the standoffs to the board. Seemd to be holding up pretty well.
