Author Topic: help centipede audio/reg to pcb  (Read 1613 times)
sonetdude
  • Last login:November 19, 2008, 05:28:20 pm
« on: July 27, 2008, 01:19:41 pm »
can someone help me on this , I have a audio/reg 04, no 5v  at all on this board, only 36 vac and 22vdc .my question is do i need 5vdc on the audio/reg board or no and the schematic,  shows 5vdc and 12volt and 22vdc this is comming from connector j10 pin 1 3 4 9 12, the print shows a 02 reg/audio going to the main pcb,I have and 04??
thanks
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: help centipede audio/reg to pcb
« Reply #1 on: July 27, 2008, 02:31:22 pm »
If your machine should have a -02 then you should be using a -02.
Here is the compatibilty list. The -04 is for a few vector games only:
http://www.elektronforge.com/AudioRegs.htm
NO MORE!!
Level42
« Reply #2 on: July 28, 2008, 02:58:02 pm »
Yup, the 04 is not going to work for the Centi....
But you could add the missing parts :)
