Author Topic: How do i cut this formica?  (Read 9179 times)
nullb0y
  • Slow In Fast Out
    • WAT Racing
« on: July 27, 2008, 03:35:40 am »
Hello,
I purchased some formica was told at the store to just use a normal jig saw blade
Bad idea
broke it quite a bit almost wasted an entire $45 sheet but managed to save enough to make my CP
right now it looks like this:
http://forum.arcadecontrols.com/index.php?action=dlattach;topic=49712.0;attach=105548;image
Obviousily i need to cut it down, i ordered some different jigsaw blades but have a feeling i will wreck it
Someone suggested just using a utility knife and cutting through the top surface and snapping it downwards
Will that cause an uneven edge? if so how do i clean the bad edge up?
Slow In Fast Out
NickG
  • Last login:September 27, 2025, 08:06:19 am
  • Dig.
    • My Projects Page
Re: How do i cut this formica?
« Reply #1 on: July 27, 2008, 05:33:47 am »
The best tool is a laminate trim bit + router
It is worth it to buy a router.  The one in the link is not very impressive, but if this is all you need it for it will get the job done.  If not, then it is wise to look for a more fully-feature model.
I did not have a router when I built my first project, and I tried many tools with poor results, and a few accidental cuts into the control panel's MDF edge.  I eventually used a circular saw + a guideboard and cut through both layers to make the edges flush.  This method worked very well, but resulted in a slightly smaller CP.
Chadwick
  • Last login:January 11, 2010, 03:23:34 pm
« Reply #2 on: July 27, 2008, 10:54:51 am »
Laminate router with a flusht trim bit with ball bearing is the best solution.
« Last Edit: July 27, 2008, 10:58:41 am by Chadwick »
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #3 on: July 27, 2008, 11:04:13 am »
i have a router.... where do i get this bit?
Edit: theres a million at home depot and lowes which one to get?
Also, do i need to trim the pannels down then use the router? or trim With the router?
i have alot of overhang
« Last Edit: July 27, 2008, 11:28:03 am by nullb0y »
Slow In Fast Out
Chadwick
« Reply #4 on: July 27, 2008, 11:08:20 am »
You can probably find one at your nearest Lowes/HDepot.  It will either be called a Flush Trim Bit or Laminate Trim Bit.
Specifically, it is a 2-Flute, Carbide Tipped, Flush Trim Bit with Ball Bearing.  Look for a 1/4" diameter, cutting edge length between 1/2" to 1", 1/4" shank.
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #5 on: July 27, 2008, 11:12:47 am »
http://www.lowes.com/lowes/lkn?action=productDetail&productId=204429-353-91201&lpage=none
lowes has a cheaper one lol
will this work for me or am i going to fudge things up?
« Last Edit: July 27, 2008, 11:25:17 am by nullb0y »
Slow In Fast Out
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #6 on: July 27, 2008, 11:35:01 am »
Also, razor blade scoring?
should i just score this down and snap Close to the edge so when i use the router im not working through alot of extra material?
Slow In Fast Out
Chadwick
« Reply #7 on: July 27, 2008, 12:52:02 pm »
That one from Lowes will work just fine.
RE: Scoring, I throw a piece of plywood/mdf/whatever down on my sawhorses, then I clamp a 1x4 piece of lineal oak down to the plywood with the laminate in between.  Score with a laminate scoring tool a half dozen times then break.  I usually leave about a 1/2" to trim with the router.
Laminate scoring tool:
« Last Edit: July 27, 2008, 12:54:42 pm by Chadwick »
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #8 on: July 27, 2008, 05:05:49 pm »
HEy, so the router bit from lowes worked great
http://forum.arcadecontrols.com/index.php?action=dlattach;topic=49712.0;attach=105607;image
Didnt screw up ^_^ thanks guys
« Last Edit: July 27, 2008, 08:24:17 pm by nullb0y »
Slow In Fast Out
