Author Topic: DK 4-board question  (Read 3087 times)
ArtsNFartsNCrafts
  • Last login:October 12, 2020, 09:22:50 pm
DK 4-board question
« on: July 23, 2008, 10:24:49 pm »
Can anyone tell me the easiest way (if any) to undo those little plastic clip things that hold the 4 boards together on DK?  I'm trying to "rearrange" them as to make room for a high score save kit.
k thx!
WunderCade
Re: DK 4-board question
« Reply #1 on: July 24, 2008, 02:20:41 am »
Needlenose pliers....squeeze the two prongs together and push the plastic spacer out through the hole on the pcb.
The spacers look kinda like this: <--)
The prongs you want to squeeze together are the < part.
ArtsNFartsNCrafts
« Reply #2 on: July 26, 2008, 09:23:48 am »
Do they still make these little connectors, in the event that I break the old ones?  They look pretty old and brittle..
WunderCade
« Reply #3 on: July 26, 2008, 11:41:01 am »
Yes, just Google pcb spacers and look for the closest match. I found them that way before but don't recall the site.
Kevin Mullins
    • Me on Myspace
« Reply #4 on: July 26, 2008, 01:13:38 pm »
http://www.keyelco.com/products/prod15.asp?SubCategoryID=101
You can match the Keystone part # and then search a distributor like Mouser.
http://www.mouser.com/
I'm sure others carry these as well.
Bender
« Reply #5 on: July 26, 2008, 03:55:57 pm »
Mike's arcade has em to
Level42
« Reply #6 on: July 28, 2008, 02:59:54 pm »
k thx!
Yeah, I already moved my audio board as well :) Do you have a soldered or socketed Z80 ? Mine is soldered so I'll have to socket it first...
ArtsNFartsNCrafts
« Reply #7 on: August 02, 2008, 08:45:06 am »
you should definitely make a tutorial on how to do that!! I would cherish it... :notworthy:
Level42
« Reply #8 on: August 02, 2008, 10:21:54 am »
Of what, of socketing the Z80 ?
Well I'll do it like I always do it: cut off all the legs of the IC, as near to the top as possible. Then re-flow the old solderings by adding a tiny bit of new solder to every island. That makes it very easy to remove the left over legs. Then clean the soldering islands with a tin-sucker.
Then solder in a new, good quality socket and put in a new Z80 (or the kit, and put the new Z80 in the kit).
I've explained this with pictures in my Centipede thread:
http://forum.arcadecontrols.com/index.php?topic=63654.msg652707#msg652707
