Author Topic: Problem: changing res = overscan on arcade monitor  (Read 3393 times)
Ummon
  • Trade Count: (+13)
« on: July 22, 2008, 12:24:58 am »
I'm using MaLa on a standard res arcade monitor. Of course it won't do anything above 640x288, so I set that in the options, but I got overscan. However, even on my multisync, when testing the "<640x480 lo-res" feature, a similar thing happened. I didn't find anything on anything like this in a search.
Yo. Chocolate.
Stephen Hawking
Twin-X
  • Last login:April 26, 2018, 05:59:44 pm
  • Yes this avatar was stolen too!!!
Re: Problem: changing res = overscan on arcade monitor
« Reply #1 on: July 22, 2008, 04:10:46 am »
I dont have this issue?
What is your desktop resolution? (assuming you use xp)
Ummon
« Reply #2 on: July 23, 2008, 12:44:43 am »
I started out at 336x240, but also tried out 640x240 and 640x288 (the limit of its progressive range). I forgot to test 640x480 interlaced, though. (I have to redo the soft15 configuration. Simple, but I forgot before I shut it off.)
When I tried the 'lo-res' feature on my multisync, the desktop I think was set at 1024x768.
Yo. Chocolate.
Stephen Hawking
Twin-X
« Reply #3 on: July 23, 2008, 07:05:25 am »
Could be the low res feature. Make a layout on your resolution and try again i would say.
Ummon
« Reply #4 on: July 23, 2008, 03:17:13 pm »
Ohhh. Yeah, I'll have to go in and look at the layout settings. I thought it would just automatically scale it or whatever.
Yo. Chocolate.
Stephen Hawking
Ummon
« Reply #5 on: July 29, 2008, 02:21:06 am »
I tried this, set it to 336x240 and started the layout manager, but the layout manager displayed the same (with overscan) as did the original layout in MaLa. I dunno.
Yo. Chocolate.
Stephen Hawking
