Author Topic: cannot regenerate mamewah list after changing folder contents !SOLVED!  (Read 1251 times)
northerngames
  • Trade Count: (+18)
remade the post below in case anyone else had the same issue.
Don't know why I edited it as solved only at first   :banghead:
« Last Edit: July 20, 2008, 12:12:03 pm by northerngames »
Ginsu Victim
  • Comanche, OK -- USA
Re: solved
« Reply #1 on: July 19, 2008, 10:44:58 pm »
That really does the rest of us a lot of good.
Thanks.  ::)
northerngames
« Reply #2 on: July 20, 2008, 12:06:41 pm »
it was kinda silly of me.
originally I had posted.
having trouble getting mamewah to generate the new list after changing the folder contents.
I had updated the folder contents and went to re-generate the list but instead of it generating a new list it kept showing only what was in the folder prior.
I then found out it was becuase the roms extension path names differed in the config folder for those particular emu's and after I changed that it all worked again like it should have and generated the list correctly.
« Last Edit: July 20, 2008, 12:14:11 pm by northerngames »
Ginsu Victim
Thanks for the repost. Just helps others searching on the same issues.
