Author Topic: Ms. Pac/Galaga off CL. Score! Update Pics.  (Read 5301 times)
WunderCade
« on: July 09, 2008, 08:35:37 pm »
OK, so basically I was lucky enough to score a Ms. Pac and Galaga off CL (2 days ago) for $100 each. Seller said both power-up, but don't play. I pick them up and got them home, here they are:
I've been side-tracked at my job for both days since, and finally today, I got home and dragged out an ext. cord to Ms. Pac. I plugged her in and pulled out the interlock in back and I immediately hear the monitor fire up with a nice static-pop sound as it came to life. I walk around to the front and to my pleasant surprise, there is a picture. So I wipe-down the screen and the monitor and, despite the bright sun outside, you can clearly see the game on screen. The problem is that:
1. The gamescreen is backwards, not upside down. Is that cocktail mode?
2. The Left/Right direction is reversed. So when I move the joystick left, Ms Pac goes right, vice-versa.
3. The game is on FreePlay.
Here is a pic of it:
And, it has a TWOBITS ABC card in place of the daughter board:
And TWOBIT"S calling card on the main pcb:
So my question is: How do I get it out of reverse mode? Out of FreePlay? Etc. with this TWOBITS card on it?
« Last Edit: July 18, 2008, 11:32:48 pm by WunderCade »
WunderCade
Re: Ms. Pac/Galaga off CL. Score! Now help please??
« Reply #1 on: July 09, 2008, 09:02:20 pm »
I was able to get it out of freeplay with the dips. But, there is no dip-setting for a "Reverse" mode. Or a cocktail mode for that matter.  :dunno
JeepMonkey
  • Last login:July 13, 2012, 01:51:24 pm
« Reply #2 on: July 09, 2008, 09:28:29 pm »
I can't help your problem, but I did want to stop by and say nice score!  I just try not to look at the CPO on the Galaga.
We will be seeing some new threads in the resto forum from you, correct?
Pins:  Theatre Of Magic, JP The Lost World, Revenge From Mars
WunderCade
« Reply #3 on: July 09, 2008, 09:49:39 pm »
I got it fixed. Modessit told me to switch the Green and Yellow yoke wires on the monitor and it worked like a charm. Only took a minute. WOOT!!
« Last Edit: July 12, 2008, 11:18:11 am by WunderCade »
WunderCade
« Reply #4 on: July 09, 2008, 09:54:17 pm »
Yep. I'm gonna need a lot of input. The Galaga was on located in the ladies backyard cover patio next to her sliding glass door. Well, over the years, as she sprayed down her patio concrete she didn't bother to protect the Galaga and so the wood is swollen with dry rot up about 6 inches from the bottom all the way around the cab. And worse, both sides are pulling apart from the cab in those areas.
JeepMonkey
« Reply #5 on: July 09, 2008, 10:17:28 pm »
You ended up getting a $100 Ms. Pac to work.     :cheers:
Sorry to hear about the Galaga.  Sounds like you have some work ahead of you.
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« Reply #6 on: July 11, 2008, 05:20:14 pm »
I hate you, nice score
I b**ch. People listen!!
Mauzy
« Reply #7 on: July 11, 2008, 09:18:36 pm »
Lucky! I assume you haven't otherwise you would have said it already, but have you fired up the Galaga yet? Sounds like that rot and separation are gonna be fun.
Level42
« Reply #8 on: July 16, 2008, 10:24:50 am »
Is that the 2nd Ms.Pac you were talking about Wunder ?
I am interested.......
WunderCade
« Reply #9 on: July 16, 2008, 08:39:29 pm »
Yes it is.  :D I got rid of that monitor, it was out of wack and skewed, so I pulled the monitor out of the Galaga and luckily, the Galaga monitor (WG K4906) still works.
« Last Edit: July 16, 2008, 09:00:01 pm by WunderCade »
WunderCade
« Reply #10 on: July 16, 2008, 09:05:18 pm »
Ya, unfortunately, the Galaga didn't come up. The marquee light works and the monitor powered on but no game on screen. Haven't had a chance to pull the boards, etc. but the monitor is now in the Ms Pac and I order a Galaga Switcher adapter from Bob Roberts. Once I get clean power...I will start trouble shooting the Galaga board.
WunderCade
Re: Ms. Pac/Galaga off CL. Score! Update Pics.
« Reply #11 on: July 18, 2008, 11:33:33 pm »
***UPDATE***
So, it was time to finally address Galaga. When I plugged it in, the monitor and light and speaker were fine, but no game board sounds or anything on screen. I looked at the power pcb and it had some burn marks and jumper hacks on it and I suspect it was probably toast. So I ordered Bob Roberts Galaga switching PS w/ adapter for 45.00. It arrived today and I installed it:
I powered it on and I heard the board test mode over the speaker. So I turned it off, pulled the monitor back over to the Galaga from the Ms. Pac machine and powered it on again and it got stuck on this screen and kept resetting over and over as I opened the coin door:
So I looked back inside the coin door and the black test switch was on test mode...I slid that switch over, it reset and this time...it went through and the game came up and I played a few games:
...and like Ms. Pac...this one needs clean up and some major body repair from water damage. But for a total of 200.00 + (45.00 to Bob) for a working Galaga and Ms. Pac. I'm a happy camper.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #12 on: July 19, 2008, 02:51:11 am »
That's so cool  8)  I can only imagine the excitement when you plug it in and it works.
WunderCade
« Reply #13 on: July 19, 2008, 03:05:12 am »
Ya, since I bought them "non-working"...and didn't have to do much to get to work...it is very cool. I always wanted a Galaga. The Ms. Pac is my second one, so I suspect I'll actually make a profit here and have a Galaga as part of it. Sweeet!
« Reply #14 on: July 19, 2008, 08:57:54 am »
wanna sell either? Ive always wanted a galaga and my moms always wanted a mspac
WunderCade
« Reply #15 on: July 19, 2008, 11:27:29 am »
The Ms. Pac will be for sale - local pick-up. The Galaga goes into my collection after restoration...as a grail.
Mauzy
« Reply #16 on: July 19, 2008, 12:24:34 pm »
Glad to see they both ended up being easy repairs!
Level42
« Reply #17 on: July 19, 2008, 06:26:32 pm »
You sure you won't ship the Ms. to me ?  :laugh:
« Reply #18 on: July 19, 2008, 07:52:58 pm »
where is "local" to you?
WunderCade
« Reply #19 on: July 19, 2008, 09:06:17 pm »
West Coast. Central Valley, Cali.
« Reply #20 on: July 19, 2008, 09:15:17 pm »
not to filled you thread with off topic, but move to the east coast and then I'll buy it off you, cause I'll be local then :)
awesome pick up, I cant wait to see the restores on them
torez
  • Last login:December 20, 2009, 09:40:12 pm
« Reply #21 on: July 20, 2008, 05:01:50 pm »
It's the greatest feeling when you tweak couple of things on the cab you just got and the game becomes alive again:).
Official Omega Race WR Holder:
1 credit:  3,847,350
2 credit:  4,823,750
grichard
  • Last login:June 12, 2010, 10:36:31 am
« Reply #22 on: August 13, 2008, 07:09:14 pm »
Congratulations! What a great score! You must be the kind of daily CL checker that gets to anything I've ever seen on CL first. I can only imagine how happy you were when they both ended up working.
WunderCade
« Reply #23 on: August 14, 2008, 02:49:17 pm »
It was pretty kewl. But I actually thought for sure I was too late cause it was such a great deal. I emailed 4 hours after she posted not even expecting a response back.
She emailed me back..."You realize it's 100 a piece right?"
I emailed back..."Oh yes, in cash. And it's a firm commitment from me." Gave her my number etc.
I was just lucky, most of the time, I have the same bad luck most do - too late.
« Reply #24 on: August 14, 2008, 03:23:25 pm »
That's good luck for sure.  Around here you have about 90 seconds to get that deal done.
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #25 on: August 14, 2008, 03:42:43 pm »
For sure. I'm glad I'm in no rush to get some new cabs (when we eventually move to a different house I'll have more room for cabs), so right now I'm monitoring CL multiple times a day. Mainly I'm trying to get a feel for the market here, but if I come across a can't-pass-up deal, I'll find somewhere to put it! I inquired about what looked like a really good deal on a SF2 cab recently and when I heard back from the guy it was gone.
Moral of the story: if it looks like a good enough deal that you're wanting to buy, don't delay. Drive over to the seller and check it out - you can ask questions once you get there, but if you email a bunch of questions on a low priced cab, you're likely to lose out on it! Or at the very least call rather than email.
Ummon
  • Trade Count: (+13)
« Reply #26 on: August 14, 2008, 05:17:33 pm »
Nice. Too bad you're not keeping both (although the mspac monitor had pretty bad burn.)
Yo. Chocolate.
Stephen Hawking
robstraws
  • Last login:August 29, 2017, 12:28:32 am
« Reply #27 on: August 14, 2008, 05:27:05 pm »
Yeah someone was GIVING AWAY a quicksilver pinball the other day on craigslist and I just missed it.  I need to remember to check every day now.
WunderCade
« Reply #28 on: August 14, 2008, 05:30:39 pm »
I already have a Ms. Pac. No need for me keeping this second one. Just selling it to get my investment back.
