Author Topic: Noooo monitor got squished!  (Read 2463 times)
scurvy
  • Last login:July 23, 2008, 11:31:43 pm
« on: July 07, 2008, 07:12:17 pm »
 :(  ok so i was playing a game and then all of a sudden my monitor got 'squished' like it is in the picture.. i dont know much about the monitor.. i was able to buy it and set it up though  8)  the controls for the monitor do nothing to fix the problem.  :-\   so i'm pretty much in the dark as to what to do now..  :dunno
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
Re: Noooo monitor got squished!
« Reply #1 on: July 08, 2008, 04:19:59 pm »
So, your topic says Nooo monitor. So does this really mean new??? If so I think you may have been a little mislead. The serial number seems to indicate made in April 2007.
Korek and Neotec then to do some pretty funny things when it comes to good design practise. I have seen them both use yokes that should have ben used on say a mid-res monitor on VGA and multi-syncs.
This causes the Horizontal circuit to work way too hard and take out HOT's and electrolytics. The kortek actually runs the yoke so hot that the epoxy that secures the yoke windings got so hot and cracked/melted.
First back to is this new... if so go back to where you bought it and check out the warranty. Should be at 1 year but becomes void if you attempt un authorized repair.
If out of warranty inspect all electrolytic capacitors for any signs (even slight signs) of the top bulging out. That is likel what is wrong.
good Luck
Rick Nieman
www.niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
« Reply #2 on: July 08, 2008, 06:13:34 pm »
I think  he was implying that he was screaming NO and dragging out the O sound.
scurvy
« Reply #3 on: July 08, 2008, 09:19:38 pm »
yeah.. i meant NOOO..
Thanks Rick.. but none of the caps looked like the were 'bulging' in any way.
i bought the monitor..... 13 MONTHS AGO!! so no warranty. :timebomb:
i cant believe i spent $525 on this monitor and its fried 1 year later.
« Last Edit: July 08, 2008, 10:29:48 pm by scurvy »
Arm123
  • Last login:March 03, 2025, 11:26:20 am
« Reply #4 on: July 09, 2008, 01:24:10 am »
Just cuz a cap is not bulging, doesn’t mean they are good.
You, or a friend, should pull off a few caps around the deflection IC's and see if they are running with in spec.
I wouldn’t run the monitor too long in this state, or you’ll have to replace more components.
Minimum, its a couple caps.  Worse case, its one of the IC's
Hopefully one of the others that are more experienced will elaborate and share some experience with this make / model.   :)
grantspain
« Reply #5 on: July 09, 2008, 01:47:35 pm »
had the same fault on a chassis today,dry solder joint on the width transistor(mine was a bdx53c)-this chassis is brand new  :o
scurvy
« Reply #6 on: July 09, 2008, 07:51:56 pm »
if anyone in the south florida area (i'm in fort lauderdale) would be willing to come to my place and fix it for me i would be so happy.. of course i would pay this person.. i'm going to call some shops around here and see if anyone has experience with arcade monitors.. and hopefully i can find someone to fix it. I've never even used a soldering iron so i'm not going to attempt this.
Rickn
« Reply #7 on: July 12, 2008, 01:20:45 pm »
Try contacting Carl Blessing at Allgood services he is a good technician and he also happens to be one of my distributors. Tell him I sent you.
Allgood Technical Services Inc
3951 Forsyth Rd Ste C18, Winter Park, FL 32792-6828, United States  (Map)
Phone: (407) 657-1600
Rick Nieman
519-621-1722
MonMotha
« Reply #8 on: July 13, 2008, 05:56:41 am »
If it helps somebody troubleshoot, I've heard (though not personally witnessed) that the mode switching can go nuts on these and get stuck in the wrong state.  Things like it will be setting the deflection outputs up for VGA, but you're feeding it standard res.  I could potentially see that causing something like this.  However, I don't know what causes it as I've never had it happen to mine or any that I keep in touch with the techs on.
It seems that some people get fairly good Kortek monitors while others get outright duds.  They seem capable of building decent stuff, but their QA and substitution engineering must be kinda, well, terrible.
