Author Topic: MAMEWAH help  (Read 4481 times)
heinekenlvr
  • Last login:January 19, 2022, 01:27:17 pm
MAMEWAH help
« on: July 06, 2008, 01:28:14 pm »
OK, so I download the newest version of mame(v.125) and mamewah(v163). Everything gets unzipped and I follow the mamewah setup as described on this site.  Mamewah opens without any trouble to the configuration page. So far so good. I put the zipped rom files in the mame rom file. I open mamewah and tried to generate a games list but with no success. It doesn't register the roms. I checked the ini file to make sure I had the right pathway and I do. I'm at a dead end. Should I be using a different version of mame?? Thanks for the help.
Ginsu Victim
  • Comanche, OK -- USA
Re: MAMEWAH help
« Reply #1 on: July 06, 2008, 04:05:32 pm »
First question: Do you have the rompath line in mame.ini in your MAME program folder pointing to your roms? (This is more than likely the issue)
Second: In x:/mamewah/config/mame/mame.ini what do you have for list_generation_method?
heinekenlvr
Re: MAMEWAH help
« Reply #2 on: July 06, 2008, 04:22:04 pm »
Hi,
I checked the rom_path in the mame ini file and it shows C:Documents and Settings...\mame\roms . This matches up with the mame rom directory.
As for the second question, it shows rom_folder_vs_listxm for the list_generation_method.
I assume that the newest version of mame is compatible with the mamewah??
Ginsu Victim
Re: MAMEWAH help
« Reply #3 on: July 06, 2008, 05:23:44 pm »
Could you copy and paste the contents of your mame.ini (from mamewah) for us to see?
gonzo90017
Re: MAMEWAH help
« Reply #4 on: July 07, 2008, 01:24:59 am »
Not sure. But I think you need xml2info. Download it and place it inside your mame folder.
http://mame.3feetunder.com/xml2info/
Re: MAMEWAH help
« Reply #5 on: July 07, 2008, 08:10:26 am »
Probably a typo, but you need a \ after 'C:'.
Might be worth trying a folder for Mame which does not have long names. eg c:\mame (much easier to configure things this way as well).
Yes it is compatible and that is the correct method (again, assuming the missing 'l' is a typo). Note xml2info.exe is not needed for this method.
heinekenlvr
Re: MAMEWAH help
« Reply #6 on: July 07, 2008, 05:23:07 pm »
OK, so I decided to paste my mame.ini file
### mame.ini (mamewah v1.63) ###
emulator_title                            Arcade
### List Generation Settings ###
rom_path                                  C:\Documents and Settings\guy\Desktop\mame\roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file                           [emuexepath]\catver.ini
list_generation_method                    rom_folder_vs_listxml
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline                      C:Documents and Settings\guy\Desktop\mame\mame.exe [name]{nodosbox}{nosafelaunch}
post_emulator_app_commandlines
general_app_commandlines
### Artwork Settings ###
artwork_image_paths                       [emuexepath]\snap
movie_preview_path                        [emuexepath]\previews
movie_artwork_no                          1
enable_fuzzy_search                       0
history_dat_file
history_dat_artwork_no                    2
### Screen-Saver Settings ###
enable_music_in_screensaver               1
select_random_game                        0
saver_type                                gamelist_slideshow
movie_path
movie_fullscreen                          1
quit_delay                                0
saver_commandline
### Additional Settings ###
music_path
lcd_display_file_path
description_display                       [description]{scroll}
### Settings used by MAMEWAH ###
current_list                              0
Anything seem wrong? Thanks for the help.
Ginsu Victim
Re: MAMEWAH help
« Reply #7 on: July 07, 2008, 05:27:47 pm »
Yep. Missing the \ in this:
Should read C:\Documents...
heinekenlvr
Re: MAMEWAH help
« Reply #8 on: July 07, 2008, 06:53:54 pm »
Thanks. I shall give it a try now.
heinekenlvr
Re: MAMEWAH help
« Reply #9 on: July 07, 2008, 07:58:59 pm »
We have success! Well sort of. Now MAMEWAH has compiled my list of games. When I try and load one it shows 'loading' for a second, the screen blinks and then returns to the MAMEWAH screen. Obviously I have missed something.
mamearcadefreak
  • Newbie
  • Last login:August 17, 2009, 01:46:11 pm
Re: MAMEWAH help
« Reply #10 on: August 17, 2009, 01:41:01 pm »
hey im new here and i was wondering  that if you guys can help me with my game snaps and movie previews
