Author Topic: 1W Maplins DIY Amplifier kit  (Read 6567 times)
david656
  • Last login:June 01, 2017, 10:06:24 am
  • Big Man!
« on: July 03, 2008, 05:27:33 pm »
i bought one of these things yesterday and started to make it at midnight and finished around 3am and then today connected up the wires to a MP3 and speaker and well the results are some what shocking ! the static on the line is awful and out powers the weak sound anyway and makes it a total waste of my time and money ! does anyone know why it could be putting so much static buzzing out onto the line ?
1W Amp with a set gain of 50
Requires a 4 - 12v power supply
my favorite part is its not suitable for under 3 year olds  :laugh2:  :soapbox:  :censored: i mean ! when have you EVER seen a four year old casually soldering a PCB ? making his own tap on night light etc !!!
any hints would be nice
http://www.maplin.co.uk/module.aspx?ModuleNo=2921&doy=3m7
PS that looks NOTHING like the one i have ! even though its ment to be the same thing ! and the picture on the box is different to the components inside the box ! i mean they have changed colour and shape a bit !
(except resistors of course !
Level42
Re: 1W Maplins DIY Amplifier kit
« Reply #1 on: July 04, 2008, 05:35:32 pm »
What were you drinking that it took 3 hours to solder 3 caps, 3 resistors, 1  IC and 1 pot ? :D
Are you sure all solderings are 100%. No shorts ?
What are you using as a power supply ?
Ed_McCarron
« Reply #2 on: July 04, 2008, 05:36:31 pm »
Its not the most advanced amp, from the looks of the pic.  Make sure your power supply is clean.  If you're using a wall-wart, toss an electrolytic cap (rated for 2x your voltage, maybe 3300uf-ish) across the power leads to smooth the DC out.
Try powering it from a decent sized battery and see if the problem goes away.
Level42
« Reply #3 on: July 04, 2008, 05:41:23 pm »
Yep, that's why I asked about the power supply...good suggestions.
I incidently built this amplifier. I use it on my Mario Bros. cab and works great (running from the Nintendo Power Supply):
http://www.velleman.be/product/view/?lang=en&id=9181
Blanka
« Reply #4 on: July 04, 2008, 06:01:15 pm »
I'm about to use an amp like this:
2x65 watt gainclone. Serious stuff  ;D
1 watt will do for Space Invaders, but later titles sound much better with a little beef in the amp.
Level42
Blanka
« Reply #6 on: July 05, 2008, 04:39:38 am »
@topicstarter:
Its a pre-amp. You cannot use that for powering speakers. Sure it will sound crap.
Level42
« Reply #7 on: July 05, 2008, 08:06:47 am »
@topicstarter:
Hah ! Now how  did I overlook that ! :D
Ed_McCarron
« Reply #8 on: July 05, 2008, 10:17:36 am »
@topicstarter:
Ha!  Sure, go ahead and actually READ the page he posted...  Thats cheating.   :D
