Author Topic: Wire bundling in side cabinet how do you do it?  (Read 2291 times)
stan2323
  • Last login:January 13, 2023, 06:05:19 pm
  • Major Retired USS Enterprise Commanding
    • My home page
« on: July 02, 2008, 08:02:24 am »
I was wondering how some of you bundle wire inside your cabinet.  After some thought I decided to use Velcro held in place using a #8 ¾ wood screw with a ¾ inch fender washer.  They are easy to screw into the wood, will not poke through the ¾ in plywood, can be used over and over, they are cheap, easy to use, and are secure enough to hold the wired in place.  See pictures below.
What methods have you used?
Careful what you wish for you may get it!!
There are 10 kind of people in the world those that understand binary and those that do not!!
Re: Wire bundling in side cabinet how do you do it?
« Reply #1 on: July 02, 2008, 08:25:43 am »
I used some self-adhesive plastic clips. Basically the same idea as the velcrow, but a rounded clip goes around the wires.
  • Last login:December 05, 2025, 04:38:46 pm
« Reply #2 on: July 02, 2008, 08:40:48 am »
Nintendo cabinets have screws with black twist ties attached to them. I reuse those a lot.
ddrtist
  • Last login:October 03, 2008, 12:51:08 pm
« Reply #3 on: July 02, 2008, 09:52:19 am »
I used a lot of those plastic staples with 2 small nails on them.  You simply place your wires between the staple and gently tap it into the wood.  It gives you flexibility because if you want to give the wire some slack you can just leave it untapped by a small bit.  The wires will still retain tension as well.  I especially liked these when wiring the sound and various computer cables I had floating around inside my cab.  If you need a picture of what I am talking about, I can probably come up with one.
Ken Layton
  • Guru
  • Technician
« Reply #4 on: July 02, 2008, 11:06:07 am »
Most game manufacturers use white nylon cable clamps and 4" zip ties. That's also what I like to do.
Franco B
« Reply #5 on: July 02, 2008, 11:46:38 am »
I'm using zinc plated U staples and 3" zip ties.
