Author Topic: Config files for neo geo.  (Read 1357 times)
boogieman
  • Last login:January 19, 2019, 05:35:48 pm
  • advancedspuds.com
    • advancedspuds - your source for spudgun information
« on: July 01, 2008, 05:45:40 pm »
I have read about making a .ctrlr file for neo geo games.  I found this thread: http://forum.arcadecontrols.com/index.php?topic=73532.msg760034#msg760034 and downloaded the .cfg file from there.
This is my question.  In the file it says:
            The following keys must be mapped to shifted buttons using WinIPAC or equivalent.
            P1B8 and P2B8 can also be used (if 8 buttons per player are not required
         <port type="UI_PAUSE">
            <newseq type="standard">KEYCODE_P</newseq>
         </port>
         <port type="UI_CONFIGURE">
            <newseq type="standard">KEYCODE_TAB</newseq>
         </port>
         <port type="UI_CANCEL">
            <newseq type="standard">KEYCODE_ESC</newseq>
         </port>
         <port type="UI_ON_SCREEN_DISPLAY">
            <newseq type="standard">KEYCODE_TILDE</newseq>
         </port>
I have my jpac set up where p2 button 7 = ESC. and p2 button 8 = P (pause)  I can change this to where the esc and pause are set up to p1 button 8 and p2 button 8.
What I am wondering, is how do I need to modify that .cfg file to work with my setup?
It is going to be setup like
  4 5 6
  1 2 3
7
I suppose I need to know how to modify that file for my use.  I do have some basic code knowledge and such but thought I would get some "professional" opinions before destroying the code lol.
boogieman
  • advancedspuds.com
Re: Config files for neo geo.
« Reply #1 on: July 02, 2008, 01:33:51 pm »
nevermind... I think I figured this out looking at the code.  The part about shifting the keys is not really relevent to the code.
