Author Topic: So I built my MAME Cab, now i want to have a PCB of an original running as well  (Read 1565 times)
mrclean
    • Guscade
OK so hmm, lets see.. I already built my MAME cab is there any way to have it run a pcb inside it as well ? like maybe get a kvm switch or whatever so when i want to run MAME i can, and when i want to run the actual PCB / ROM board I can ? is this possible. Using U360 sticks and rest of my buttons are hooked into a Mini-pac? Sort of going the other way this time.. id like to build a dedicated.
2,370,650 Gun.Smoke
Singapura
It depends a bit on your board but the easiest way would be to wire your cab Jamma compliant and use a jPac. There are multi-Jamma boards available where you can plug in any Jamma board and your PC.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
What he said ...
Working: Not Enough
Projects: Too Many
Progress: None
