Author Topic: Atari2600 emulator out of sync in arcade monitor **FIXED!**  (Read 2064 times)
amiga500
  • Last login:December 29, 2024, 10:09:10 pm
I have installed MAME 0.125 working great and now I want to install 'Stella' an emulator for the Atari 2600 system.
I'm using Maximus Arcade as the front end.
The problem is when I launch an Atari game the monitor gets out of sync/resoution. I tried the few different options that the emulator shows but nothing fix it.
I have installed Soft15Khz, only the 15Khz mode, hace not installed the 25 and 31khz mode because the monitor had a double image with them.
I don't know if it possible to run atari2600 games on an arcade monitor.
I copy and paste here the .ini file for stella.exe:
Code: [Select]
;  Stella configuration file
;  Lines starting with ';' are comments and are ignored.
;  Spaces and tabs are ignored.
;  Format MUST be as follows:
;    command = value
;  Commmands are the same as those specified on the commandline,
;  without the '-' character.
;  Values are the same as those allowed on the commandline.
;  Boolean values are specified as 1 (or true) and 0 (or false)
video = soft
dirtyrects = 0
gl_filter = linear
gl_aspect = 2.0
gl_fsmax = 1
gl_lib = libGL.so
gl_vsync = 1
scale_ui = zoom2x
scale_tia = zoom2x
fullscreen = 0
center = true
grabmouse = false
palette = standard
colorloss = 0
sound = true
fragsize = 2048
freq = 31400
tiafreq = 31400
volume = 100
clipvol = true
sa1 = left
sa2 = right
p0speed = 50
p1speed = 50
p2speed = 50
p3speed = 50
pthresh = 600
showinfo = false
ssdir = .\
sssingle = false
romdir = c:\
rombrowse = true
lastrom =
modtime =
debugheight = 0
launchersize = 2
uipalette = 0
autoslot = false
Thanks :cheers:
« Last Edit: July 02, 2008, 03:14:19 pm by amiga500 »
EVEGames
  • Last login:December 03, 2025, 10:06:10 pm
Re: Atari2600 emulator out of sync in arcade monitor HELP
« Reply #1 on: July 01, 2008, 03:09:07 pm »
Amiga500,
You might want to give Z26 a try: http://www.whimsey.com/z26/z26.html
I've had no problems running it on an arcade monitor.
-EVEGames
massive88
« Reply #2 on: July 01, 2008, 03:35:51 pm »
I dont have an arcade monitor, but wouldnt Mess be a good choice for compatibility?
amiga500
« Reply #3 on: July 02, 2008, 01:09:43 am »
Ok, I'll try those emulators.
thanks :cheers:
EVEGames
« Reply #4 on: July 02, 2008, 12:33:43 pm »
Amiga500,
I almost forgot, the "official" version of Z26 is not 100% cab friendly, but there is an alternate version that is.  Get it here:
http://www.localarcade.com/screenshotarchive/downloads_emus.htm
Massive88,
I may be out of the loop with the latest MESS developments, but last time I looked, their Atari2600 emulation left much to be desired.  Unlike their Colecovision and Vextrex which are spot-on.
-EVEGames
amiga500
« Reply #5 on: July 02, 2008, 03:13:22 pm »
Amiga500,
Massive88,
-EVEGames
Thanks man, it works on my arcade!
