Author Topic: 8liners chassis problem  (Read 5564 times)
Cisek
  • Last login:May 19, 2023, 07:35:14 am
« on: June 26, 2008, 03:44:55 pm »
Hi
I've got problem with centering the image on my Hantarex Polo tube with 8liners chassis, h-size position potentiometer "jumps over" the center position, making the image go far too right, or far too left. I made a video that shows the problem -
I would be very grateful for any help.
grantspain
Re: 8liners chassis problem
« Reply #1 on: June 26, 2008, 06:02:55 pm »
bet it don't have a problem with a jamma board connected,reckon its something to do with you pc side
Cisek
« Reply #2 on: June 26, 2008, 08:16:20 pm »
No it don't work with jamma either.
The problem is the postion of the image - I can't center it, it's too much to left side, or too much to right side of the screen. The edges are cut for few inches, looks like don't display the whole image, even if I narrow the horizontal width. When turning the h-pos pot it is "jumping over" the center. I noticed also that the image is shaking a little bit, it looks like some kind of noise, however when I turn the image maximum to the right or left, the shaking noise disappears.
I am using new 8liners chassis on Hantarex Polo tube. Looking forward to your advices.
Narrowed screen -
grantspain
« Reply #3 on: June 27, 2008, 06:37:11 am »
you get the same problem with a jamma 15khz board connected?
what was the original chassis and what is the replacement model numbers?
what are the yoke reading?
Cisek
« Reply #4 on: June 27, 2008, 07:28:30 am »
The original chassis was geniuine Hantarex Polo chassis. I bought an MK2 cab with all original, non-replaced components. Thge replacement chassis is 8liners chassis for 25" monitors. I can't read the yoke, as I don't habe multimeter.
grantspain
« Reply #5 on: June 27, 2008, 07:56:37 am »
o.k should be good,you may have a faulty chassis-have you contacted 8liners yet
Cisek
« Reply #6 on: June 27, 2008, 08:34:36 am »
I am waiting for their reply.
I noticed also the image isn't displaying the whole resolution - the right and left
sides of the screen are cut of for a few centimeters. It is visible in the
second video i made (look at the timer on the right bottom corner, and on the
windows logo on the left bottom corner to see it).
I was given an advice to adjust he horizontal width coil on the
chassis itself, however I can't find it on 8liners chassis (on original hantarex chassis I know where it is) and I don't know if this will help.
I also found info that on the chassis there is 3 position jumper for small/medium/large horizontal width (first post) - http://forums.webmagic.com/ubbthreads/showflat.php?Cat=2&Number=317415&an=0&page=0
I can't localize this jumper however.
« Last Edit: June 27, 2008, 08:48:35 am by Cisek »
grantspain
« Reply #7 on: June 27, 2008, 09:08:34 am »
if i had a good photo of the chassis i could probably id the jumper(if its there)
Cisek
« Reply #8 on: June 27, 2008, 12:31:39 pm »
Ok i found one jumper, but it is just for switching between H+V and V.C.
I still can't localize the coil, I found the pot that is there where should be coil, but it adjusts the V-size, not the H-size (I marked that pot with yellow circle) - http://img98.imageshack.us/my.php?image=dsc03590qp0.jpg
Also noticed there is some yellow paste around one capacitor and dunno whether it is OK, or    this cap already got dried out - http://img233.imageshack.us/my.php?image=dsc03592lw3.jpg
The chassis is Jen Shinn, model 329.
grantspain
« Reply #9 on: June 27, 2008, 01:22:21 pm »
i do not see any width jumpers on the pics you have supplied
the stuff around the cap is glue-wonder where the other cap is though(maybe a u.s modification)
i can't get on the jen shinn site to check the specs
this could be a faulty chassis-how long have you had it?
Cisek
« Reply #10 on: June 27, 2008, 01:37:15 pm »
This is the third day. I bought new one from genao.com
All other things are great - contrast, brightness and that stuff, only h-position is bad. Maybe it's tube fault? I remember that on old chassis I had similiar issue, but with v-size (The picture was too much stretched vertically and I couldn.t shrunk it)
« Last Edit: June 27, 2008, 01:45:29 pm by Cisek »
grantspain
« Reply #11 on: June 27, 2008, 01:46:35 pm »
i have done a lot of chassis swaps and the likes,important that the yoke matches the chassis
i believe your yoke is o.k as you would have more geometry problems and this is not a tube fault
the problem is the picture is way oversize on the horizontal so you can't lock the hold or centralize the pic
now the only things to cause this would be the horizontal width adjustment not working,fault on the width circuit or b+ too high
i know these chassis work on polo as i helped someone else the other day with this setup
you have adjusted the horizontal size yes?
Cisek
« Reply #12 on: June 27, 2008, 01:52:32 pm »
Horizontal size pot is working, however the picture can't be centered the problem seems to be the h-postion potentiometer. I set B+ lower, but it didn't help. All other things are good. Geometry is excellent.
grantspain
« Reply #13 on: June 27, 2008, 01:57:23 pm »
tried the horizontal hold yet and what sync connection are you using?
Cisek
« Reply #14 on: June 27, 2008, 02:06:14 pm »
I am using composite sync I don't know what is horizontal hold.
grantspain
« Reply #15 on: June 27, 2008, 02:08:47 pm »
maybe called horizontal  frequency pot on the control board(normally)
Cisek
« Reply #16 on: June 27, 2008, 02:19:58 pm »
Tried all the pots on control board, no one helps.
grantspain
« Reply #17 on: June 27, 2008, 02:29:30 pm »
how narrow does the picture adjust?
Cisek
« Reply #18 on: June 27, 2008, 02:43:09 pm »
It can be narrowed really much, that there are huge black boarders on the left and right side. However when it's narrowed the left or right edge of the screen is a little cut of (the cut side depends on how I will adjust the picture by the h-pos pot - it can be too much to left, or too much to right). It just dont display horizontally the whole resolution, even when narrowed.
grantspain
« Reply #19 on: June 27, 2008, 02:46:38 pm »
got to be a faulty chassis,get it swapped ;)
castlesteve
  • Last login:September 12, 2014, 09:10:32 am
  • uh, yea
« Reply #20 on: June 27, 2008, 06:35:36 pm »
Ive had quite a few of these things.  For the most part they work ok.. but are very tempramental with some tubes and yokes.  Even to the point where it wont even warm up the tube some days but will on another identical tube and yoke.
So, if you have the ability, try another tube/yoke before you return.... else I think you will end up in the same situation.  8liners guys will not really work with you on diagnosing the problem nor will you EVER get a schematic.
is what it is.
Cisek
« Reply #21 on: June 28, 2008, 06:21:17 am »
I managed to fix the problem. Instead of moving image to the right I decided to manually change the soft15khz resolutions that I am using (which however originally worked good on my previous chassis). As you know, or maybe not this is a program that can create custom resolutions. So for example I can have all the arcadevga resolutions with good old Radeon 9550. I contacted the creator of this program and he told me how to change resolutions to move it a little to right. It was a little bit difficult, however now all resolutions are centered and they are not cut of by sides.
Thanks a lot for your help.
grantspain
« Reply #22 on: June 28, 2008, 06:37:04 am »
thats why i asked about if you had a jamma board to test it with,90% of these type of faults on all the arcade forums are caused by graphic card setup
glad you got it sorted :)
Ken Layton
  • Guru
  • Technician
« Reply #23 on: June 28, 2008, 10:34:44 am »
All these monitor replacement boards were designed to be used with a real arcade board video signal. Never intended to be used with other sources.
Cisek
« Reply #24 on: June 28, 2008, 11:23:40 am »
There is still one, minor problem - when I stand close before the screen, the image seems to "shake" a little bit.
grantspain
« Reply #25 on: June 29, 2008, 06:26:11 am »
probably still something to do with the graphic card setup
Cisek
« Reply #26 on: June 29, 2008, 08:34:44 am »
I am using connections from this picture -
I noticed also I have linearity issue. The space beetween the bottom lines of the image is tighter than on the top. The more to the top of the image, the bigger are spaces beetween lines. It's very noticable when playing vertical shmups.
I think there is the pot on the chassis that regulate the linearity, can you tell me where it is?
grantspain
« Reply #27 on: June 29, 2008, 09:01:45 am »
look carefully for a v.lin pot-if i had a schem i could tell you
Cisek
« Reply #28 on: June 29, 2008, 11:19:22 am »
I've found this pot and adjusted it. I just can't believe that the 15 year old tube, which for it most time was used for 6-7 hours daily, may produce such a vivid and colorful display. The image is still a little "shaky" hiwever it is only slightly visible, when looking very, very close to the screen.
Time to play some mame!
grantspain
« Reply #29 on: June 29, 2008, 11:43:27 am »
happy days :cheers:
