Author Topic: Stuck on trackball hookup (pics included)  (Read 1462 times)
clickhea
  • Last login:August 09, 2019, 07:33:40 am
« on: June 25, 2008, 03:19:47 pm »
2 connections from the MINI-PAC for the trackball
iam assuming this is the ground wire from the trackball?
where does this go?
harness from the trackball (the harness from the minipac does not fit into this)
no idea what is suppose to go where.. any help would be appreciated.
trollnest
  • Last login:September 02, 2008, 02:10:42 am
  • ayo gukali!
Re: Stuck on trackball hookup (pics included)
« Reply #1 on: June 25, 2008, 03:34:58 pm »
my happ trackball has 4 pin connectors like these on the optic boards, will those plug into these? also, thats a static ground. I believe its okay to just wire it to cab
*edit* from ultimarc: The Happ trackballs have a green ground wire. This is to prevent static buildup and can be connected to any convenient ground point.
« Last Edit: June 25, 2008, 03:38:47 pm by trollnest »
clickhea
« Reply #2 on: June 25, 2008, 03:53:14 pm »
i have 2 of those red boards attached to the trackball, how would i know which harness goes to which board
trollnest
  • ayo gukali!
« Reply #3 on: June 25, 2008, 03:55:38 pm »
 :dunno just try, if the axis are reversed, try reversing them.
clickhea
« Reply #4 on: June 25, 2008, 04:39:22 pm »
thanks for the help
as for my tt2 spinner do i want it on the x or y axis or is this somthing i have to see according to my trackball?
