Author Topic: On analog controls...  (Read 1081 times)
TheManuel
  • Last login:April 09, 2025, 10:13:43 pm
  • On and off hobbyist
« on: June 03, 2003, 11:17:58 am »
Is one axis of an analog stick the closest replacement to an actual paddle or is a spinner(dial) better?
What is the main difference between a paddle and one axis of an analog stick?  The range of motion?
Thanks.
"The Manuel"
Re:On analog controls...
« Reply #1 on: June 03, 2003, 12:04:23 pm »
I believe an analog stick effectively does the same as a paddle...I personally am going to mount a seperate paddle on one of my controls panels - you can make one yourself using a 100k pot wired to the gameport.  So this is a close to a real paddle as you can get - because it is one!
A spinner will not work well as a paddle, since it uses optics.  A bit like playing OutRun with a 360degree wheel - it works but it's not how it should be.
TheManuel
« Reply #2 on: June 03, 2003, 12:16:23 pm »
Got it.
Thanks.
"The Manuel"
