Author Topic: ArcadeVGA + O/S + Frontend  (Read 2393 times)
mafiasilk
  • Last login:June 04, 2003, 06:11:02 pm
  • Newbie PC to Jamma Converter
    • MalikNET
« on: June 03, 2003, 07:40:43 am »
I have just finished restoring an OLD Jamma cabinet I purchased from eBay, it has a 20" Samsung arcade monitor, 2 players and 6 buttons per player.
The PC im using is a AMD K6 400Mhz, 392mb, 6gb HDD, AWE64 PnP ISA Card.
I was wondering if someone can help me on recommending the O/S I should use to play mame.
What frontend would you recommend?
I tried the Fraggle Boot CD, and It didn't work with my setup?
I now have a Windows 98 setup, and waiting for a F/E, I want to remove the keyboard and mouse eventually and hide the PC in the back of cabinet.
Help appreciated for a newbie!
I used the Jpac and ArcadeVGA card from Ultimarc to complete this project.
Regards.
Mafiasilk.
Just learning the ropes!
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
Re:ArcadeVGA + O/S + Frontend
« Reply #1 on: June 03, 2003, 07:55:19 am »
Regards.
Mafiasilk.
I personally would boot win98 into dos with that machine and use either gamelauncher or advancemenu as the fe
if you boot in to windows then both are still a good choice because they are very fast. Alternatively I would suggest to first try a relative simple windows based fe like mamewah to see how it works on your computer.
peter
« Reply #2 on: June 03, 2003, 07:56:54 am »
I personally would probably use Windows 98, booting in DOS along with ArcadeOS.  That should work pretty well I would think, with those PC specs.  But you could always boot up Windows and give WinMAME a try to compare performance...you do have quite a bit of RAM...
« Reply #3 on: June 03, 2003, 07:57:51 am »
You beat me to it )p(  :D
mafiasilk
    • MalikNET
« Reply #4 on: June 03, 2003, 12:10:50 pm »
Do you mean 98 loading and then shutdown to dos? or the msdos.sys trick and GUI=0 etc etc to bypass loading 98?
Thanks for the info so far!
Appreciated.
« Reply #5 on: June 03, 2003, 01:06:16 pm »
Edit msdos.sys, yes.  This is a nice clean way of doing it, plus you can add ArcadeOS (or whatever FE) into your autoexec.bat so it runs straight after you switch on :)
mafiasilk
    • MalikNET
« Reply #6 on: June 04, 2003, 06:48:47 am »
Excellent info! Thanks, works like a dream and fast too for a 400Mhz chip!
Only thing I need to do now is download SB Awe64 PnP ISA Drivers and im away!
Many thanks....
Also a quick note, Arcadeos needs a special mame.dat file for arcadeos to work with the correct resolution for each game. Just a tip from the Ultimarc site.
mafiasilk
    • MalikNET
« Reply #7 on: June 04, 2003, 06:13:27 pm »
Got the AWE64 working in DOS, but now I have a problem with vertical games not rotating in arcadeos?
im playing Zaxxon, and nothing I add to arcadeos.cfg or mame.cfg makes a difference?
im using win98 (hacked msdos.sys to boot with no GUI, and configured 98 DOS with drivers for sound)
can anyone mail me their working cfg's?
thx
